Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 01-16-2006, 06:44 AM
  #1021
Trader Rating: 15 (100%+)
M04
Is anyone having problems with chassis tweak on the M04M? I replaced the kit servo saver which reduced the problem somewhat. Besides not hitting every board on the track , is there anything else that can be done to fix this problem?
blewer is offline
Old 01-16-2006, 09:19 AM
  #1022
what servo saver do you guys use? Also has anyone used ceramic balls for the diff? I have a TA03F ball diff I am building.
natskiboy is offline
Old 01-16-2006, 09:31 AM
  #1023
jw92656's Avatar
I am using the Kimbrough large. You have to drill to two extra holes a little lower in it though.
I have been using the tungsten diff balls, and I polish the diff rings before assembly.
I have been using 30wt oil all around (two hole), HPI radials front, and HPI x-patterns in the rear. Both have HPI green inserts trimmed to fit the smaller diameter.
Ride height at SoCal is 5 front, and 6mm rear. I also set the tweak on the car, even though I get harassed for it.... have all the electronics stufts inside the rear part of the chassis too.
Hope this helps.
jw92656 is offline
Old 01-16-2006, 09:59 AM
  #1024
jw are you using a TRF damper?
Old 01-16-2006, 10:13 AM
  #1025
jw92656's Avatar
Yeah. I did build them with two o-rings in the front, and one o-ring in the rear. Use the equivilent plastic spacers, and you'll be good to go.
jw92656 is offline
Old 01-16-2006, 11:03 AM
  #1026
I bought my car used. It came with red and white springs, anyone know which one is stiffer?
Do I really need the carbon gear shaft? does it make a difference?
Old 01-16-2006, 12:24 PM
  #1027
Steven Key's Avatar
Tamiya Mini Springs:
Red-Soft
Blue-Med
White-Firm
So the white is firmer or stiffer than the red.
The only advantage to the carbon fiber gear shafts is overall car weight saving. The shafts themselve don't a actually rotate they just hold the bearing for the gears.
Steven Key is offline
Old 01-16-2006, 12:26 PM
  #1028
RaceBucks's Avatar
Originally Posted by jw92656
... I also set the tweak on the car, even though I get harassed for it....
John, I was one of those guys harassing you ... until you lapped me!
Jeff Smith
RaceBucks is offline
Old 01-16-2006, 12:47 PM
  #1029
what spring combo do you guys run on a hight bite carpet? I have TRF dampers
Old 01-18-2006, 01:53 PM
  #1030
What's the best tire/insert combo for Trackside?
Ryan F is offline
Old 01-18-2006, 06:40 PM
  #1031
Default Is this TCS legal
I just modified the steering part so it has more caster.
I use my old optional part 53226 RC Aluminum Front Hub Carrier (1/10 4WD/FWD Touring Car).
Can I use it for TCS ?
rcmnx is offline
Old 01-19-2006, 04:24 AM
  #1032
rccardr's Avatar
rcmnx-
I'd send an e-mail and photo to Tamiya USA, attn Fred Medel to get an official answer, but my guess is that it would not be legal. Their rules state that the part has to be from (or a designated option part for) the chassis it's used on. Since the Mini never had a carrier option...
rccardr is offline
Old 01-19-2006, 06:25 AM
  #1033
Steven Key's Avatar
Ryan F
The tire combo for Tracside in Milwaukee is:
Fronts, "S" grip stuff with inserts to make them firm. This can be done a number of ways.
Rears, "M" grip with normal Mini black shaped inserts.
My son Matt and I race Mini's every Tuesday night, we would be happy to help and answer any set-up questions you have on Mini's.
Old 01-19-2006, 07:19 AM
  #1034
Thanks Steven,
I just finished my Mini yesterday. I'm going to practice at Trackside today. I can't wait.
Ryan F is offline
Old 01-19-2006, 09:04 AM
  #1035
Steven Key's Avatar
Ryan,
Good luck, come on down Tuesday night and race with us.
I sound like a game show host.
