Tamiya mini cooper
#7488
Trader Rating: 23 (96%+)
#7489
have any1 tried,
mo3 vs mo3R, which its better handling, i have heard that m03r mada some correction to the traction roll problem of the mo3. is it true?
some also claims mo3r faster, that y its have a "R"
#7491
Should handle almost the same except the R will have a small slight edge due to oil shocks vs friction shocks.
#7492
I'm not a M03 experts but I did notice a couple of things...
1) the front alloy uprights have a 3rd hole for the steering linkages, I'm not sure but I think it gives more Ackerman. Also the potential steering throw seems more because the linkage do not hit against the side of the gearbox.
2) Rear alloy uprights has additional hole, though I think it is not used. Could be an additional tuning option.
#7494
Any more info on the new HPI Mini?
#7496
THAILAND '09?
Check this out guys..
The TITC (Thailand International Touring Car Championship)for '09 will also have a Mini class!
http://www.titc.in.th/
#7498
I think not Jeff.... They're allowing 4WD Minis as well so the M03's will get slaughtered..
As Cal will tell you, that's a super high-grip track, so keeping an M03 on its wheels will be hard enough as it is, let alone contending with 4WD cars as well.
#7500
53597 are the rebuildable type. i.e. better
