Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-06-2008, 06:16 AM
  #6301
Originally Posted by tony gray
Dec's post about 6 above this one... R10 is pretty much the only place. No-one in the States stocks them, and they're even hard to get in Japan.
Chevron is just a one-man operation so they cant pump them out like other companies can.
Oh..and they don't have any in stock at the moment anyway!
Do you have a web address for R10? I would like a Chevron Monster M body as well.
Spoook is offline
Old 03-06-2008, 06:29 AM
  #6302
TryHard's Avatar
Originally Posted by Ben.C
Hi, has anyone tried the new alu shocks yet??
Not yet... but I was looking at them vs the std tamiya blues.. and IMO, your better off going for the standard set.
Main reason is that a) the standard ones are cheaper, b) they come with delrin pistons c) have the alloy adjuster ring and spring holder.
Hence why I brought a set of the standard ones to replace the Silver TRF's I sold to someone else
HiH
Ed
TryHard is offline
Old 03-06-2008, 08:56 AM
  #6303
Wicked-Wayz's Avatar
Trader Rating: 19 (100%+)
Originally Posted by ozoner
And by replying and having a whinge, you're doing.... what?
Bump!
(for w-w). Anyone got any updates on when type-A slicks will be available again? Champ told me end of March, but they also told me that Tamiya are looking for someone else to do their tyres because the price has just increased from their current supplier. So who knows.
Yea same difference but whatever moving on. I heard from my local shop that they should be coming to them in the middle of april. I couldn't even get any mini tires for the first tcs race.
Peace Aaron(W-W)
Wicked-Wayz is offline
Old 03-07-2008, 06:13 AM
  #6304
Core Creations's Avatar
Trader Rating: 109 (100%+)
If anyone is interested I have a couple of the 4 slot Johnson motors (much higher RPM than the current 2 slot Johnsons) for sale. These are getting very hard to find. Race ready . PM me if interested.
Core Creations is offline
Old 03-07-2008, 12:31 PM
  #6305
tony gray's Avatar
Details are on our site
tony gray is offline
Old 03-07-2008, 01:03 PM
  #6306
rcarmchl's Avatar
Trader Rating: 15 (100%+)
Can anyone help me locate the Titanium Turnbuckels for the M03 and M04?
rcarmchl is offline
Old 03-07-2008, 01:53 PM
  #6307
tony gray's Avatar
Part No 53527 - 32mm
They're readily available. Tamiya USA have them listed, as do etamiya.
Old 03-07-2008, 02:10 PM
  #6308
rcarmchl's Avatar
Thanks tony - I must have had th wrong part number cause I couldn't find em.
Where does eTamiya ship from?
rcarmchl is offline
Old 03-08-2008, 09:36 AM
  #6309
Are the kit tires with the Suzuki Swift 60D? I am wondering if I need to double stuff the kit tires. Also if I double stuff should I be using 24mm or 26mm inserts?
Spoook is offline
Old 03-08-2008, 10:14 AM
  #6310
tony gray's Avatar
The kit tyres will be lucky to last 2 battery packs....so double stuffing them would be a complete waste of time.
Old 03-08-2008, 10:23 AM
  #6311
If you are only running carpet then yea double stuff. If your on pavement I would choose another tire. I think it is 24mm that you would use. I can't remember exactly. I have used my kits tires for about 8-10 runs. They are still fine to use but not what is suggested at my track.
Peace Aaron(W-W)
Old 03-09-2008, 12:20 AM
  #6312
caltek1's Avatar
Trader Rating: 38 (100%+)
Thumbs up EXIGE AND 60D TYRE STUFFING
This post deals with only those that run the Exige BL system in their Mini.
Well I had problems for the last couple of weeks with the Exige system in the MIni. The problem was that the speedie would loose signal from the radio and go into shutdown mode. This caused the car to stop and the only way to get it to rebind was to turn it off, disconnect the battery and then reconnect and turn on.
If you don't disconnect the battery and only turn it off the speedie will only run at about three quarters throttle for the complete race.
Problem was the connection inside the RX. Pulled the connector out, cleaned RX and then reconnected. Will have to rebind the speedie to the radio and then problem solved.
For double stuffing of 60D tyres, a sorex insert 24mm either A firm, C firm etc with the foam works well on the front. Just take your time when stuffing into the tyre and check the tyre is sitting on the rim properly prior to glueing.
This is good for asphalt and painted boral concete surface's.
You do not need to cut down the insert and the insert sits closest to the tyre carcass.
Hope this post helps someone.
Later
Calvin
caltek1 is offline
Old 03-10-2008, 02:40 PM
  #6313
Redwings's Avatar
Default Mini one way
Does anyone have the part number for the mini oneway. Looking at putting one in. feedbacks welcomed.
Redwings is offline
Old 03-10-2008, 03:49 PM
  #6314
TryHard's Avatar
why would you want a one-way in a mini...
You would have absolutely no braking affect going into the turns... it would just roll forever. On a tourer it's different, as you have the rear diff helping to slow the car, but in a mini, they are freewheeling anyway. So if you put a one-way in and you'll have four wheels freewheeling as soon as you come off throttle...
But if you want to run one, well, I guess a TA03 one would fit, as it's the same size etc as the ball diff
TryHard is offline
Old 03-11-2008, 12:07 AM
  #6315
Oneway???
Are you running a Tamiya mini or some other brand of 4WD mini ????
Ben.C is offline
