Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 12-06-2007, 07:34 AM
  #5551
RC MARKET's Avatar
Originally Posted by Core Creations
Here's the updated version:
Good & Thanks !
RC MARKET is offline
Old 12-06-2007, 01:53 PM
  #5552
akura2's Avatar
Originally Posted by bowl806
Hey there Akura 2- That Mini looks familiar; I'm sure it runs as good as it looks
Thanks.... actually it DOES run really well... but I need to get it to SoCal to see how it runs on a tighter track... at Sun Valley it kicks butt... but that track is HUGE...
akura2 is offline
Old 12-06-2007, 02:09 PM
  #5553
akura2's Avatar
Originally Posted by mep
akura2 your real Cooper is awesome
Thanks...
getting it back out of the shop soon... can't wait... wish it was before Friday so I could drive it to the track....
akura2 is offline
Old 12-08-2007, 01:05 PM
  #5554
Trader Rating: 32 (100%+)
Default charging batt for my m03m
hi,.. still new in this hobby,... need some advice from u expects.
i am using muchmore cellmaster v1.0 to charge my stick pack (IB 4200mh) batts for my m03m. i do have a few questions about the batt.
a) i charge the batt at 2.0A, 3mV, cut off at 4600mh, is that ok???
b) after using the batt,... i need to discharge them... at what amp & to what voltage??
c) if i wanna keep the batt after race,... to what mh should i charge them??? for how long i can keep them before i discharge & recharge the batt???
d) what is the diff if i discharge the batt using cellmaster & using spintec batt manager???
tq
hobbs is offline
Old 12-08-2007, 01:37 PM
  #5555
i don't think you have to worry about discharge. 4200maH don't hold a memory so when it slows down I think all you have to do is recharge-but not more than 2x per day
bowl806 is offline
Old 12-09-2007, 12:27 AM
  #5556
tony gray's Avatar
Lotsa updates at rc-mini.
A report on the latest big race for us, the Peter Stevens/HEI Masters, plus some stunning new bodyshells from Tim and Steve Rhoads...
Click here to see it all.
tony gray is offline
Old 12-09-2007, 02:56 AM
  #5557
Tamiya1218's Avatar
Trader Rating: 16 (100%+)
Default M03 Servo saver...
hi I'm new this M03,
Anyone can help me about the servo saver!
I'm using Sanwa WRX on the steering on M03m,
try to use original servo saver but is easy drop out!
Can i using the Tamiya Hi Torque servo saver 510000?
but found the original servo saver part is longer that Hi Torque servo saver!!!
Anyone using it?any advise?
Thank!
Tamiya1218 is offline
Old 12-09-2007, 06:10 AM
  #5558
Takt's Avatar
Trader Rating: 15 (100%+)
I've got a Swift. Yesterday race, it started "chattering" everytime I turned left ... then later in the day, it chattered both ways (left was a high speed corner). It wasn't rubbing on the body ... body wasn't dragging. Any thoughts on what it could be? It appeared to be "wheel hop". THanks
Takt is offline
Old 12-09-2007, 09:14 AM
  #5559
asw7576's Avatar
I won M04M Mazda Eunos ( Miata ) as a doorprize today.
I want to ask you mini coopers fans, is M04 rear wheel drive easy to drive ?
Any building or setup tips ?
asw7576 is offline
Old 12-09-2007, 09:45 AM
  #5560
Nice door prize. Post pics when you put it together.
studysession is offline
Old 12-09-2007, 09:53 AM
  #5561
Suspended
i'm not mini, I am very large
homosexual r/c is offline
Old 12-09-2007, 11:32 AM
  #5562
tony gray's Avatar
Thank!
What do you mean 'drop out'? We have no trouble with the original equip servo saver. Are you sure you have the correct spline insert on?
It's almost certainly rear wheel hop and is quite common. Can be fixed in a number of ways. Ride height adjustment, rear springs and/or tyres.
Old 12-09-2007, 12:30 PM
  #5563
PizzaDude's Avatar
I ordered in some of the Spice Dish-rims.
They are all crooked and warped
Big dissapointment.
Inserts look nice though.
Anyone else have similar experiences with the Spice rims?
PizzaDude is offline
Old 12-09-2007, 12:52 PM
  #5564
RC MARKET's Avatar
Big dissapointment.
We HK market not have this case .
Ride had this case !
Old 12-09-2007, 01:42 PM
  #5565
Burlap's Avatar
Big dissapointment.
All the Spice rims I have had have been fine.
Burlap is offline
