Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 12-10-2007, 08:53 PM
  #5581
Originally Posted by over gear
how many tamiya 60D are there? i found type-A slick and M-grip on tamiyausa.com
The normal stock 60D & S-grip.
Ben.C is offline
Old 12-10-2007, 09:47 PM
  #5582
over gear's Avatar
Trader Rating: 18 (100%+)
OK, correct me if i'm wrong... i counted 4 60D's : normal stock 60D, S-grip, M-grip, and Type A
What's the difference between them grip-wise? i know they look different.
over gear is offline
Old 12-11-2007, 06:43 AM
  #5583
Hawk6's Avatar
Trader Rating: 52 (100%+)
Stock 60D = "kit tire", treaded = not race worthy?
S Grip = "Super Grip" treaded tire
M Grip = "Medium Grip" treaded tire
Type A = slick, not sure of hardness or "grip-iness" relative to S grip and M grip
For carpet on M03m, I use S grip in front, M grip in rear.
Hawk6 is offline
Old 12-11-2007, 06:57 AM
  #5584
Takt's Avatar
Trader Rating: 15 (100%+)
Speaking of tires.
I ran some "older" tires over the weekend and really liked the way they handled. I then put on brand new tires, and my car pushed like a dump truck. Is this normal? Do they have to break in before they start working? Is there a way to quicken the breakin process?
Takt is offline
Old 12-11-2007, 11:29 AM
  #5585
Trader Rating: 114 (100%+)
Type A Slick will work on Carpet...You have to stay in the groove. I believe the A slick is like a S Grip
The stock kit tires, I heard last year the guys were using them for the Novak Race.
For some people the Threaded tires have worked for them because they clean out better than the Slicks.
Takt,
The New tires will need to be scuffed in.
I would believe they would get better after a couple of runs.
Also the track needs to have a good groove to for them.
I know Monroe is new so could be one of your problems too.
What compound are you using at Monroe?
I hope this helps
Dave
dragracer72nova is offline
Old 12-11-2007, 11:36 AM
  #5586
Takt's Avatar
Dave --
I am running the s-grip and m-grip ...same setup as Trackside. With the "old" tires, it turned very well. New ones not so much. You are right, Monroe doesn't have a groove yet.
Is there a way I should scuff the tires? Run a dremel across them or sandpaper or something? Or just run them until they come in?
tim
Takt is offline
Old 12-11-2007, 12:07 PM
  #5587
Core Creations's Avatar
Trader Rating: 108 (100%+)
I have definately noticed a difference in old and new tires. For whatever reason the old worn tires always work better for me.
Core Creations is offline
Old 12-11-2007, 12:21 PM
  #5588
Originally Posted by Takt
Dave --
tim
One way of scuffing the tires.
Is do a burnout on your driveway, rotate tires(front to rear) then repeat.
When I scuffed my Type A's in, I just ran it at Trackside.
It took about 4 or 5 runs for the tires to get the grazing off but it worked.
The slicks you can not do the burnout on the pavement. The S & M Grips have a little more meat to the tire than the slicks.
I would use the nice smelling Paragon for Monroe to get the tire's scuffed in.
Dave
Old 12-11-2007, 12:43 PM
  #5589
Customworksking's Avatar
Trader Rating: 74 (100%+)
Default mini
S and M's
Customworksking is offline
Old 12-11-2007, 04:13 PM
  #5590
mep
mep's Avatar
Trader Rating: 40 (100%+)
From reading this thread in the past, I determined that the new tires are not made the same... some specific chemical in the rubber recipe was banned, or something along those lines. I think this holds true for many, if not all of the Asian RC tire manufacturers. Retrace this thread, the posts are back there somewhere... or Tony might chime in & confirm.
I just opened a new old stock pair of standard m-chassis radials(55d for the M-01 - not 60d) with the old packaging, and a brand new recently-stocked pair of the same part number, and they are completely different. The old pair from the mid-90s is very soft with a white residue on them, & the brand new pair(same exact part number, but with a new hang tag label) is stiff, slick & they even have a much stronger smell. The new tires feel like vinyl
mep is offline
Old 12-11-2007, 04:20 PM
  #5591
ScionBox's Avatar
Questions from a Mini newbie:
My friends and I have started our own small Mini basher racing series, and we were thinking about running regular touring car size wheels & HPI X-patterns since they are readily available at the local hobby shops in our area. Tamiya stuff is scarce around here.
Are there any pros & cons of running touring car size wheels & tires on the Mini??? (Other than having to cut out the fenders a little more.)
Should we change out the pinion?
One of our racers said we should run HPI 31mm Vintage wheels & tires... I say no... they may be a little too wide and affect performance badly.
Thanks!
ScionBox is offline
Old 12-11-2007, 04:28 PM
  #5592
ScionBox's Avatar
Probably since crude oil is near $100 a barrel, they probably changed the 'recipe' to more vinyl in order to save some money. The older tires might have had more of a petroleum rubber base to them.
ScionBox is offline
Old 12-11-2007, 05:27 PM
  #5593
tony gray's Avatar
The situation as I understand it, is that there was a specific compound that nearly all the manufacturers used in their tyres that was identified as being somewhat 'nasty'
Not necessarily to the end users, but earlier on in the manufaacturing phase.
Hence the fact that nearly all rubber tyres have now changed to some extent. There's no question that they're different now.
Touring Car tyres on Minis? OK for mucking around, but it stuffs up the suspension geometry big time and the car handles like crap....
tony gray is offline
Old 12-11-2007, 05:52 PM
  #5594
over gear's Avatar
Tamiya 49483 Mini Cooper Racing Lightweight Body
does anyone know which mini body it is?
Old 12-11-2007, 06:50 PM
  #5595
Trader Rating: 22 (100%+)
Default Wheels
Thanks!
A mate of mine had a mini with TB02? susp arms, touring car wheels run by 5.5 brushless. Handled great went like a bullet. Downside was after a while gears sort of wore out.
Team Ash is offline
