Tamiya mini cooper
http://www.kamtec.co.uk/epages/BT464...Products/K0050
Can't vouch for fit or finesse, but definitely cheap.
Also check out teambluegroove on ebay, they do a few Golf shells.
I have a M05v2 upgraded chassis; I recently found out that I needed the 1.6mm spacer for my diff of which I didn't have before.
Problem is; When I put the spacer in as per directons; the diff binds. My only assumption is the motor plate I am using is still the older M05 motor plate; not the V2.
Since it clearly fits; should I bother to get another motor plate?
Thanks Big Dee for the shims; I'll return them if I don't need to get another motor plate.
The M05 motor plate and the M05 VerII motor plate are different offsets.
You need to use the VerII plate with the VerII chassis.
Today I used some wire to stitch up the front of my Mini. I have no idea if/for how long this will hold up, but I sure do like the look!
Nahh..! That was like.. over.. a month ago. Man, it has really taken some beating But, this is my first car and I guess it's to be expected. And I've got two other bodies waiting to get painted!
I think the hardest hits came just a week ago (not counting a couple of spectacular jumps out of the raceway), when I installed a differential stiffing kit, and I just couldn't control the car. It turned out it was mostly the controller settings that were making my driving so twitchy, and yesterday after a friend adjusted some settings, I was really able to keep up with the big boys. Even shaved almost a second off my previous PB lap time that was done with the default open diff! Still, got a lot to improve on my driving lines..
If you also coat the damaged area with ShoeGoo it should last a bit longer.
R/C Tech Elite Member
Gorilla Clear Repair tape! Clean the surface to be repaired with alcohol/brake cleaner/monkey spit first. Apply the tape to the flattest area first. Heat with a blow dryer or heat gun and mash it down into the curved areas. You might have to do a relief cut if it gets to a point where it's going to bunch up.
The stuff is strong as hell, flexes and sticks like there's no tomorrow.
Thanks for all the suggestions guys! I'll see how I'll go about patching it further if/when it disintegrates any further. Currently there's some tape used to patch steam pipes behind the cracks, and it seems to stick nicely. The application wasn't the best though, so the stitches have some actual function in addition to good looks!
I don't know if we have Shoe Goo or anything similar where I live, but I do know that we have Gorilla tapes. I have a roll of the basic black one myself, and have been really happy with it.
So I've just been watching a build log of the Monte Carlo Mini M05 kit, and noticed that he had a serious issue where the body didn't actually fit on the chassis. It looks like the rear portion of the chassis has the version 2 droop brace added, even though it's a version 1 kit. Has anyone else noticed this kind of problem before?
Skip to the 16 minute mark if the link doesn't take you there directly.
https://www.youtube.com/watch?v=7SM4ELMYpUQ&t=16m00s
