Tamiya mini cooper
Has anyone tried the new version II chassis on their version I car ? Will this help the handling problems ? Are other parts needed ? I'm about to order some parts and have the option of buying the chassis.
The main reason I changed the chassis was so that I could run just one type of battery in all my cars. This probably works against my handling problems.
Here's an example of something I believed was a principle and used to quote a lot. It was pretty much accepted by all that Minis ran best with toe out. One degree was minimal and the usual setting was one to two degrees. As I learned more, I discovered that this was not a principle but just BS for the newer set ups we had gone to. As in all things, things change and evolve, so it's best not to get too dogmatic about things.
Anyone got one for sale? Funny I started this thread years ago and thinking of coming back. Looking for an M05. Please email me at [email protected]
There is one thing that is a principle, but will only make sense to the thoughtful. I almost always lately, make some sort of a change on every single run. Doesn't always make it better, but you'll always learn something----even if it's "don't do that again". Another one is to not run more than a few laps if the cars not handling. There are others and most of us have them.
Believe me, I'm only just half kidding or joking.
Just read my post and realized that it pretty much echoes advice I got early in my R/C car experience. I started at SoCal Raceway which was the home track for a number of factory drivers and any number of talented amateurs.
Essentially, this is what I was told. Put in a lot of track time and keep on working on your car. It took a long time to finally figure out what they were saying. In my last post, I translated it for you-----otherwise it could sound like a non answer.
I have. I can't say it made a huge difference. Although I kept the original motor mount. I have just ordered the V11 motor mount, so hopefully that makes a difference.
Hi all
I'm having an issue with my new 51000 saver and Tamiya alloy horn on my M05 V2. It's mounted on a brand new Savoz 1251 and it has a lot of play, as the horn is sliding back and forth quite a bit over the plate with the 3 rings. I've had these before on my old M05 with no issue. I put the two gold rings on first and then the black ring last. I've tried the servo with a sold horn to check it and it's nice and tight.
I don't really want to go for a Kimborough as I liked the old Tamiya horn and saver on my M05, and I guess a solid horn would just kill the servo or bust something else in a hard crash.
Any ideas?
Cheers!
Any ideas?
Cheers!
295Likes
