Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 01-20-2014, 12:26 PM
  #20221
AudioStylz's Avatar
Trader Rating: 15 (100%+)
Originally Posted by jha07
Can someone tell me what is the min ride height for TCS rules.
I want to say the ride minimum ride height is 5mm. At least that's what I remember from my last TCS event. 1300g minimum weight.
AudioStylz is offline
Old 01-20-2014, 01:47 PM
  #20222
Core Creations's Avatar
Trader Rating: 108 (100%+)
I can't recall ever having my minis ride height teched on carpet or asphalt at a TCS event. Most here run them close to 3mm in the front.
Core Creations is offline
Old 01-20-2014, 02:02 PM
  #20223
R/C Tech Elite Member
monkeyracing's Avatar
Did some advance searching through the tamiyausa.com/tcs site. I could find no mention of ride height, save for a few items under class descriptions, none of which were minis. They really should just have a complete, downloadable pdf file, linked at the top of the page.
In other words, slam it into the weeds.
monkeyracing is offline
Old 01-20-2014, 02:18 PM
  #20224
CraigMBA's Avatar
Trader Rating: 22 (100%+)
If the track has a ride height rule (to keep from snagging the carpet), use it. Otherwise.....
CraigMBA is offline
Old 01-20-2014, 05:50 PM
  #20225
KA2AEV's Avatar
Several of the tracks that we ran at during the TCS event did check our ride height, but it was to avoid any snagging on the carpets, not at the outside tracks at all, so its probably going to be enforced as to the local race directors decision
KA2AEV is offline
Old 01-20-2014, 07:42 PM
  #20226
AudioStylz's Avatar
Makes sense to have a ride height rule for carpet tracks. I never have seen a ride height rule posted on Tamiyausa either. Most likely just a rule to protect the carpet tracks and nothing more.
Old 01-21-2014, 03:47 PM
  #20227
KA2AEV's Avatar
Does anyone know if the Gear Diffs for the M03 & the M05 are the same part?
KA2AEV is offline
Old 01-21-2014, 06:11 PM
  #20228
kwkride's Avatar
I don't know if they're the same part number, but they are interchangeable.
kwkride is offline
Old 01-21-2014, 06:21 PM
  #20229
The outdrives are slightly different in the way they input into the actual diff, but they are interchangeable between either chassis. I actually prefer the M03 version over the 05 as long as you get the hardened outdrives.
Old 01-21-2014, 09:01 PM
  #20230
KA2AEV's Avatar
I kind of made a booboo
Previously I had changed our main drivers gear diff to a ball diff (Thats an 05)
and recently I changed my gear diff ( thats an 03) to a ball diff, but I had some troubles with it and want to change back to the gear diff until I can figure out whats wrong
and never marked which one is which (BooBoo) They do look alike, but wasn't sure if physically they were.
Thanks Guys
KA2AEV is offline
Old 01-21-2014, 10:39 PM
  #20231
If you're talking about the stock gear diffs, there are two versions. The original M03 gear diff and the one that came with some (early) M05 used a splined output. The later/current version uses a rectangular output.
Old 01-22-2014, 10:39 AM
  #20232
KA2AEV's Avatar
Well gee thanks alot now Jim
You really threw a Monkey Wrench into the works!
Yes they are the stock ones and now I gotta figure out which one
is one!
KA2AEV is offline
Old 01-22-2014, 10:50 AM
  #20233
Either version will fit either car. The only difference is the outdrives and the two outer gears they connect to inside the diff.
Splined
Rectangle
Old 01-22-2014, 12:34 PM
  #20234
Hi all,
I'd like to explain how my swb M03 is (or isn't) handling at the moment and get some suggestions. I've set this new car up the same as a friends car as his handles a treat.
I run blue front springs, 600cst oil, yellow (and I've tried red) rear springs with 350cst oil, zero front toe, EPA set at 80% both sides as I found the inside tyre was touching the shock at lean angle, M grip 60d tyres, rear hard roll bar, 56mm shocks, and a kit built untweaked diff, around 5mm ground clearance.
What it does is have a very loose rear end which doesn't improve as the race goes on. I've tried additive on the rear tyres with no improvement. When I stick Sweep 25 slicks on the back the car is perfect.
I'm on carpet, one track is medium grip the other is high grip yet the car does the same.
The only difference between mine and my mates cars is that his has a tighter diff.
Any ideas?
Boons is offline
Old 01-22-2014, 12:43 PM
  #20235
Yosh70's Avatar
Trader Rating: 17 (100%+)
I'm not an expert, still new to the on-road but it sounds like the same problem my little guy was having with his M05 last weekend.
What is your rear camber setting?
Yosh70 is offline
