Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 05-14-2014, 10:02 PM
  #20971
eR1c's Avatar
...and another
eR1c is offline
Old 05-14-2014, 11:11 PM
  #20972
ruebiracer's Avatar
Here are a few photos. It is cracking all around the steering posts. my steering was giving me problems when I first built my M05, ..somhoping this was caused early on and that the new setup I am using will cause less stress on my new chassis.
Your photos look really shocking!
I never saw a chassis looking so bad, and I have at least one of every M-chassis. Iīd dare to say, that Tamiya produced a bunch with bad, too hard plastics, like recently on the TT02 knuckles. You couldnīt notice any difference from the look of the parts, but everyone using them noticed them cracking by very low effort. Your edge cracking completely out is totally unknown from my M05 and my M06. (but I bought them 3 years ago)
This is not normal Tamiya quality, Iīm sure...
I hope for you, there will be revised plastics soon, like on the TT02.
Br,
Matthias
ruebiracer is offline
Old 05-14-2014, 11:33 PM
  #20973
VooDooPH's Avatar
Trader Rating: 18 (100%+)
maybe you're tightening down your screws too much?
VooDooPH is offline
Old 05-15-2014, 12:19 AM
  #20974
Clawhammers's Avatar
...and another
Holy...
Thanks for sharing the pics and these are surprising to me.
Btw, did you use original tamiya screw ?
Clawhammers is offline
Old 05-15-2014, 12:45 AM
  #20975
R/C Tech Elite Member
monkeyracing's Avatar
Wow! I've never seen one break there. It's usually front shock towers and front lower suspension mounts. I'm curious to know about how tight the screws were done up, or if there was any chemical contamination in that area. I've seen plastics (on other items) craze and crack when exposed to things like CA glue thread lock, motor spray, contact cleaner, brake clean and even silicone spray. One of my chassis actually changed colour, from black to light grey with silicone spray and showed weird stress lines in the plastics. Whatever the case, those steering posts should be a relatively low impact area, compared to the rest of the front end.
monkeyracing is offline
Old 05-15-2014, 01:26 AM
  #20976
That's an extreme break... Mini cars need attention around the screw areas with CA glue before Racing, and even more CA glue on the sidewalls of the Tires so they won't hook up to the walls in an accident....
bertrandsv87 is offline
Old 05-15-2014, 04:17 AM
  #20977
KA2AEV's Avatar
WOW!
That actually looks as if you Gorilla'd them screws in (Sorry Monkey, No Offense meant!)
How tight were the screws???
KA2AEV is offline
Old 05-15-2014, 04:56 AM
  #20978
marcos graveyar's Avatar
M05 Ver.II Pro
marcos graveyar is offline
Old 05-15-2014, 08:57 AM
  #20979
EricP's Avatar
...and another
yeaaaaaaaaaaa... don't use Loctite, buddy.
EricP is offline
Old 05-15-2014, 09:04 AM
  #20980
k_bojar's Avatar
Trader Rating: 30 (100%+)
those pics of the breaks look horrible. I've never seen anything, EVER like that... wow
I like the new one-piece arms... can't wait until they become available separately looks like a good place for some weight reduction
k_bojar is offline
Old 05-15-2014, 10:39 AM
  #20981
Raman's Avatar
Trader Rating: 94 (100%+)
Was curious how they would implement the droop adjustments... Interesting..
Raman is offline
Old 05-15-2014, 10:48 AM
  #20982
whitrzac's Avatar
Trader Rating: 97 (100%+)
It looks like your using some kind of chemicals on the chassis... Threadlock will melt certian plastics as will motorspray/electronics cleaner.
whitrzac is offline
Old 05-15-2014, 11:15 AM
  #20983
Thanks for posting pics. My shopping list so far includes chassis parts and lower arms. Will be interesting to see the guts.
Old 05-15-2014, 12:09 PM
  #20984
EricP's Avatar
Received my sample today.
Looked through the kit and the changes look promising. Hopefully this '10th' post will allow adding pics haha.
I'll try my best to answer any questions any of you may have, specifically, regarding the M05v.2
EricP is offline
Old 05-15-2014, 12:11 PM
  #20985
EricP's Avatar
EricP is offline
