Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 01-23-2014, 02:04 PM
  #20251
I have just discovered TBG bodies, has anyone tried them? is the lexan good? They have a lot fo them that are very nice, ie porsche 959, audi quatro, even their stratos seems to be nicer than the hpi's
jimjav is offline
Old 01-23-2014, 03:13 PM
  #20252
CraigMBA's Avatar
Trader Rating: 22 (100%+)
This is a TCS question, but I'm going to ask it here because it can't be original.
Assuming I don't use HPI spacers and use all Tamiya parts, can I do this?
The offset of the part is the same, only difference is one isn't made of brass.
CraigMBA is offline
Old 01-23-2014, 03:36 PM
  #20253
Trader Rating: 18 (100%+)
That is ok to do, that's how I had mine (only with tamiya spacers) and it past tech.
back9monsta is offline
Old 01-23-2014, 03:45 PM
  #20254
Originally Posted by VooDooPH
any feedback on the Honda CR-X MWB body? compared to the Swift?
Thanks!
Voodoo,
In opinion the body handled fine. Only thing I disliked about it was it doesn't Marshall itself. I tend to hit a lot of dots and barriers with the swift, LWB mini and SWB mini they tend to roll back over on its wheels or side (turn the wheel a few times and you Marshall yourself. The crx has a flatter roof so your stuck waiting for someone to flip you over.
Old 01-23-2014, 07:40 PM
  #20255
R/C Tech Elite Member
monkeyracing's Avatar
Sorry for bumping, but this got "last paged" pdq.
Originally Posted by monkeyracing
Can't recall if I've asked this already...
Anyone know how to get the m03 rear anti-roll bar to fit an m04? I've seen a picture or two, but they were too blurry to be useful.
monkeyracing is offline
Old 01-23-2014, 08:37 PM
  #20256
Schs2013's Avatar
Been using the Friction shocks will the tuned springs work on them?
or do i have to do a oil-filled set up to use the rest of those optional shocks?
Schs2013 is offline
Old 01-24-2014, 01:00 AM
  #20257
The springs will fit.
Which version of the friction shocks are you using? There are the old ones that used a piece of rubber tubing over the damper rod and there are the snap together "spring holders" supplied with current (2009-) kits.
The older version can be made to work okay with a little ingenuity. The current ones are...spring holders.
Old 01-24-2014, 05:27 AM
  #20258
Schs2013's Avatar
Exclamation
The 2009- kits snap together.
Schs2013 is offline
Old 01-25-2014, 08:42 AM
  #20259
LiamC's Avatar
Does anyone know if the Tamiya Honda CRX bodyshell (MWB) will fit the M06?
LiamC is offline
Old 01-25-2014, 03:11 PM
  #20260
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Just did a test fit and no, the rear bumper hits the two motor support rings. Only way it will work is if you hacked up the center of the rear bumper for clearance.
Dan is offline
Old 01-25-2014, 03:45 PM
  #20261
Probably the only functional mini in this area
but hey, it's fun to drive
inpuressa is offline
Old 01-25-2014, 06:38 PM
  #20262
AngryRog's Avatar
Trader Rating: 20 (100%+)
I REALLY like that motor/esc combo. Fast for a mini and always runs cool.
AngryRog is offline
Old 01-25-2014, 09:57 PM
  #20263
AudioStylz's Avatar
Trader Rating: 15 (100%+)
Got my M05 up and running for the most part. Still need a battery, and do a lot of testing/tuning. Got a few months to get it sorted out.
AudioStylz is offline
Old 01-26-2014, 09:23 PM
  #20264
Mike Schumacher's Avatar
Trader Rating: 37 (100%+)
How many aftermarket companies make gear diff for M05?
Mike Schumacher is offline
Old 01-26-2014, 10:31 PM
  #20265
Top, 3Racing, Spice...maybe one or two others rebadging those already mentioned.
My turn! How many companies made one way diffs that fit minis?
