Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 11-20-2013, 11:29 AM
  #19876
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Originally Posted by fresnojay
My problem is as traction comes up over the day it still gets harder and harder to keep all 4 on the ground. Usually towards the end of the second heat I start 3 wheeling. In the main I look like a stunt driver going around corners on 2 wheels. Now it doesn't seem to me that I am really driving any faster in the corners. But we all know its not often the case.
Sounds familiar!
Are you saying they aren't supposed to do that?
CraigMBA is offline
Old 11-20-2013, 11:47 AM
  #19877
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
I've always heard of CA'ing the sidewall on the mini tires but never actually seen it done. How do you guys apply it or is there a technique? Just smear it on and hope it doesn't make a mess?
Is this only done on 60D tires or have people done it on 55mm tires as well?
Just curious...
Dan is offline
Old 11-20-2013, 05:47 PM
  #19878
shmit 1's Avatar
I apply the glue to the middle of the sidewall using the bottle. Then put my finger inside a plastic bag and rub it around in a circular motion. I use losi standard tire glue. Works good and it stays off the tread.
shmit 1 is offline
Old 11-21-2013, 05:46 AM
  #19879
axle182's Avatar
Trader Rating: 18 (100%+)
Ive attached a pic of the tire to help with the explanation. I only use the bottle (no finger etc), and i would recommend a gel or thicker type. Its still easy to use the thin tire glue, but it runs very easily if your not careful. I use the end of the bottle to move the glue around, and slowly add CA. When I use thin CA, i put it on very lightly, to stop it running.
See the ridge on the side, right at the edge of the tread blocks? I use this to place the glue on the edge of the tread blocks, as the glue doesnt need to go up the side wall. If your using CA on the sidewall to increase the stiffness, thats another issue. To begin with, I only add about 1-1.5mm of glue from the ridge. IMHO its better to add a little more CA each time, otherwise you will need a dremel with a sanding disk. Try the 1-1.5mm, if the car still comes up, add another .5-1mm. Its ok if a little runs between the blocks, its the CA on the tread surface we are working with. Try to make sure that the extent of the CA is the same all around the tire each time. Let the CA set, with the outside of the tire facing up.
This of course is for carpet racing, we dont get alot of asphalt racing unfortunately
The reason for adding a little each time is that, especially locally, we require so much steering to be competitive, 1mm too much CA and your out of the A final. I usually put on enough to stop it traction rolling, but the car still comes up on two wheels when run very hard into a corner, but not much. this way you still have enough tread and grip to make it through the slower stuff quickly. Hope that helps
File Type: bmp
axle182 is offline
Old 11-21-2013, 06:32 AM
  #19880
Does anyone know how top speed is affected with different tyre sizes? I am running 60d tyres and going to try Sweep slicks.
Boons is offline
Old 11-21-2013, 06:35 AM
  #19881
Originally Posted by markrobinson
I clean and apply additive every run. When I've forgotten to do this I find the tyres "come in" on the 3rd or 4th lap
What additive do you use? And how do you clean them mate?
Boons is offline
Old 11-21-2013, 09:25 AM
  #19882
R/C Tech Elite Member
monkeyracing's Avatar
Yes. The difference between a 60mm and a 55mm tire is about 9%. You might get a slightly better launch on the small tire, but the lower top speed will outweigh it overall.
It's a shame. There are loads of good 55mm tires available, premounted and ready to go.
monkeyracing is offline
Old 11-21-2013, 09:27 AM
  #19883
So 55MM tires for very curvatious tracks, and 60mm ones for tracks with long straights?
pizzaboy192 is offline
Old 11-21-2013, 09:50 AM
  #19884
Thank you.
The two tracks I race on with my silver can take around 10 secs to complete and constant corners with one straight, so I'm hoping the new tyres can hold off the 60d equipped cars!
Probably a stupid question but when I drove my car around the house on domestic carpet earlier, whilst on the new slicks, it had little grip. I'm hoping it's a combination of new tyres and household carpet! Do the slicks take some bedding in? Will they certainly need additive on carpet?
Boons is offline
Old 11-21-2013, 03:02 PM
  #19885
You'll still have to be a demon on the infield to stay with the pack. It is fun going into corners really hard though.
The two tracks I race on with my silver can...
...I drove my car around the house on domestic carpet earlier, whilst on the new slicks, it had little grip. I'm hoping it's a combination of new tyres and household carpet! Do the slicks take some bedding in? Will they certainly need additive on carpet?
Silver cans might make a difference. There can be so much inconsistency between them that a high revving one could change things up.
You'll likely need a little sauce and he right carpet to make them do their thing. They don't need bedding in as much as a good cleaning and a few laps to set them straight.
Old 11-21-2013, 05:03 PM
  #19886
SerpentCT4S's Avatar
Trader Rating: 95 (96%+)
Just picked up a Tamiya M03 kit.
I am wondering what lipo I can use in it. Also, can I use a lipo with the stock ESC that came with the kit?
Also, what electronics would make it a bit faster than the silver can motor? Is brushless a bad idea for this chassis?
Thanks!
SerpentCT4S is offline
Old 11-21-2013, 06:58 PM
  #19887
cartix's Avatar
Trader Rating: 36 (100%+)
Thanks!
This lipo is perfect for it Peak Power Max Sport 45C 4200 Lipo 7.4V
http://www.tqrcracing.com/shop/produ....asp?p_id=2745
Yes you can use a lipo with the stock ESC.
cartix is offline
Old 11-21-2013, 07:09 PM
  #19888
Nice, I'll order one tomorrow.
Thanks.
Old 11-21-2013, 09:10 PM
  #19889
Thanks!
Where on earth did you find a M03 kit? I thought they weren't available any more or upgraded to M05,M06. I'm in Central Calif. so online ordering is all I have access to. Our LHS only carries off road racing stuff.
bowl806 is offline
Old 11-21-2013, 11:57 PM
  #19890
Thank you Sir.
Would you recommend a particular sauce? And how do you clean the tyres?
Boons is offline
