Tamiya mini cooper
Hi, are you using Tamiya Type A? Feel free to approach Noel or myself at JP, would love to help you out.
Joel
Joel
Hi guys,
I have an M05 S Spec, Long Wheel Base Config.
It keeps on tumbling over while turning and it is not funny anymore.
Set-up:
- front hard white springs with BLUE pen marks
- rear hard white springs with YELLOW pen marks
- tires are Tamiya slicks with medium foam inserts
- ride height is that the arms are parallel to the ground
- oil is the oil that comes with the kit
- my EPA is already at 60% and if I go any lower, the car won't turn anymore
- the tracks are asphalt high grip indoor
- shocks are the blue TRF shocks
What am I doing wrong?
Set-up:
Hi guys,
Set-up:
Set-up:
Traction rolling
+1 on CA for the front tire sidewalls and lowest possible ride height
R/C Tech Elite Member
Haven't seen many for a while, but there are real full sized cars that have teddy bear hub caps here! Is that another stoopid Aussie only thing we have?
Nope. I've seen them here as both hubcaps and as alloy wheels. Horrible in both cases.
Quick question....
Does anyone use the stock Tamiya gear diff in there cars?
Last summer I put one in my M05. I filled it with some grease I had on the shelf (?). Had a nice feel. I ran it all last year. At big races I was top of the "B" or Bottom of the "A". At club races I was always in the hunt.
Everyone else rans a Ball Diff. I tried one at the last race. The car was not to my liking.
I am going back to my trusty gear diff, but was wondering if I was the only one that liked this set up?
Chris
Chris
Chris, Tamiya TRF drivers use the gear diff (with gum). You are in good company with the gear diff.
Joel
Joel
Ackerman angle on m05, Less or more, none. what effect it on m05 ? im thinking of changing to no ackerman angle (both wheel are true to each other)
will that improve the car? I got 3racing alumiumum steering rank.
so and after taking part in WCICS I feel like smashing my mo5......no not really
I got to learn a ton. im going to say 40% car 60% skill
So when i was corner marshall all that I was thinking" DAM look at the driving lines, and on a main most of the cars were allmost at full speed for most of the track"
so the guys that run mo5's do you still run dogbones or what?
they seem to alll ways come out on me? why?
my son runs a mo3 and he seems faster on the straights why?
we both run bearings and spec motors&esc , gear diffs
as a newbie would a ball diff help me? if so what one mo5 or ta03
I notice that this thread has over 1100 pages,could someone give me direction on setting up a spec mo5
thanks for any help
thanks for any help
hotrod, just my personal thoughts.
http://www.rccarsrtr.com/index.php/t...05-tuning.html
M03 is lighter, maybe reason why it is faster.
Gear diff is good, I would stick with it. Or the TA03 fully tightened.
hth
hth
hth
hth
I know a guy at our track that sets up his mini like this (harder rear spring, softer front), which is opposite to how I set mine up (harder front, softer rear), yet we race wheel to wheel. My car is pretty good on carpet, but its on rails on asphalt.
Biggest 2 things i've found with mini setup is ride height, and tyre choice. Followed by the diff to help the corner exit and get the power down. Otherwise its mostly preferential stuff.
