Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 10-13-2011, 07:50 AM
  #15991
Suspended
Originally Posted by sosidge
Any recommendations for a car stand that holds the not-flat-bottomed Mini securely with good clearance for the wheels?
I've always felt proper "car stands" are overrated, unnecessary cost, and what I've used for most of my various cars over the years is a big fat carwash sponge, available at any bigbox store for a couple of dollars, and cut it to fit around wheels and such with some scissors or a hobby knife. Molds itself to the chassis, and any "not-flat" areas.
kaycerc is offline
Old 10-13-2011, 06:13 PM
  #15992
wollow86's Avatar
Default Spic oil filled Gear diff
So I've been running this for a few weeks now, and so far, it sucks. It leaks, and on the right side of the diff (the one that the screws go in) the gear pops off the pin that holds it to the outdrive and has managed to kill the shim under it.
I'll be ordering the 3 racing unit when feral gets them back in stock.
wollow86 is offline
Old 10-13-2011, 06:35 PM
  #15993
Are there any oil filled gear diffs that can fit the M03?
Thanks!
stocker is offline
Old 10-14-2011, 12:15 AM
  #15994
caltek1's Avatar
Trader Rating: 38 (100%+)
Thanks!
None at this time. The issue is with the internal bearing size difference between the MO3 and MO5.
I have not heard of anyone thinking about making a MO3 oil diff as most, not all have moved onto the MO5.
Your best bet would be to stick to the TAO3 ball diff.
Regards,
Calvin.
caltek1 is offline
Old 10-14-2011, 08:43 AM
  #15995
Default Turnigy
is there any Turnigy/hobbyking lipos that fit m-chassis?
hotrod306 is offline
Old 10-14-2011, 09:03 AM
  #15996
Hobbypartz has a 4000mah 25c Gens ace lipo for only $20.00 that works great. Free shiping on orders of $50.00 or more.(U.S.)
nytryder is offline
Old 10-14-2011, 09:14 AM
  #15997
Hobbypartz
well....
I have had 10 gen aces lipos ....im down to 4...not good luck
and my last order was lost....waiting for customer service to do some thing?
Old 10-14-2011, 01:53 PM
  #15998
wollow86's Avatar
I'm using those gens packs in my m05 and they work great! They drop about 1000-1100mah per 5min run for me. My gens ace in my tc are awesome too.
wollow86 is offline
Old 10-14-2011, 04:28 PM
  #15999
GasGod's Avatar
Default option front shock tower
Does this front tower(M05) really make that much difference?
If so how does it affect the handling.Are softer springs used?
Any input is appreciated-- thanks
GasGod is offline
Old 10-14-2011, 06:38 PM
  #16000
Is a savox 1251mg too small of a servo for m05?
Old 10-14-2011, 10:22 PM
  #16001
jcr
For those using the Gen Ace packs from HobbyPartz, how do you guys mount the battery in the M05? The balance wires gets in the way of the battery holder.
jcr is offline
Old 10-14-2011, 10:27 PM
  #16002
I use one in mine and it works good with speed to spare.
nytryder is offline
Old 10-14-2011, 10:29 PM
  #16003
Use the holder from an m03(it makes motor and battery removal much easier too). You can trim/dremel the m05 cover to clear the wires also.
nytryder is offline
Old 10-15-2011, 04:48 AM
  #16004
k_bojar's Avatar
Trader Rating: 30 (100%+)
its essentially the same size and similar specs as the Futaba 9550/9551 - and those things rock in 10th TC
like the other dude said, more then enough for a mini
k_bojar is offline
Old 10-15-2011, 05:08 AM
  #16005
Trader Rating: 88 (100%+)
I run a spektrum 590 servo that came with my DXR3 in my mo6, and it works great! And those servo's cost what, 10 -15 dollars? Besides, imo you don't want something to strong or two fast for these cars. I believe it upsets them too much.
MUDVAYNE is offline
