Tamiya mini cooper
Can anyone recommend a reasonably priced servo for a M-05 S-Spec? Should I be looking for speed or torque?
http://www.amainhobbies.com/product_...tal-Gear-Servo
i'm sure they are available down under as well
http://www.rcmart.com/catalog/rc-ser...Path=1099_1025
Take a look at the Hobbypartz servos.
You can try the Bluebird BMS 705MG very well priced.
Well, here are the first pics (thanks to tamiyablog) of the new M Four Tamiya 4WD chassis set. Along with what appears to be a (badly fitting) Nissan Silvia shell?
It looks nice, but LiFe power only? Hmmmmm
R/C Tech Elite Member
One has to wonder about Tamiya's fixation on LiFe technology.
The best thing about this car is we're bound to see some new bodies and other bits become available for our real M chassis cars.
i guess the Silvia body is there to show you that the wheel base is close, but not quite?
On the minis I don't find that you need the super high speed steering that is why I would prefer the torque servo over a speed servo. As long as the speed is relatively faster than a standard servo it should be ok.
I prefer servos that cost between $10-$20. Throwing a $60 servo in a mini is just silly. If you happen to get an expensive servo for cheap, however, that's a whole different story.
that is true. A servo should not cost your half the price of a mini... I think you have some better parts to buy with that money.
bluebird= kak, buy at you own risk
Some work, some fail quicky, some have centering issues, some put hash & noise into the receiver causing RX restarts(I've seen this on my oscilloscope)
I got rid of mine as it made the car (1/10 TC) wander.
Do yourself a favor, get at least a 1/2 descent servo. KoPro, futaba,
or a Savox which are quite a bit cheaper than Futaba & KoPro
