Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 10-15-2011, 05:32 AM
  #16006
wollow86's Avatar
Originally Posted by jcr
For those using the Gen Ace packs from HobbyPartz, how do you guys mount the battery in the M05? The balance wires gets in the way of the battery holder.
I just took to the cover with a dremel. Works great . I also just use a cable tie around the roll bar on the car to help hold the battery wires in place. It's just big enough to squeeze a deans through it. Then I just wedge the balance cable through the battery wires to hold it out of the way.
wollow86 is offline
Old 10-15-2011, 08:51 AM
  #16007
Do the adjustability of 2 camber link positions of the alloy rear hub benefit the m03? IN what situation would you move it to the lower link? I guess for less camber gain, but does it matter on a m03?
Thanks.
stocker is offline
Old 10-15-2011, 11:16 AM
  #16008
I bent a rear axle and snapped the front one clean off.. it broke where the pin goes through.
Replaced the rear axle with a reinforced Tamiya Axle Set (54183), but I didn't see an equivalent reinforced part for the front end. Does such a part exist? Is there another better/stronger part?
Feijai is offline
Old 10-15-2011, 12:46 PM
  #16009
@Monkeyracing
Do you still need the Xevo Chariot instructions?
Sydewynder is offline
Old 10-15-2011, 02:11 PM
  #16010
R/C Tech Elite Member
monkeyracing's Avatar
Hi, just got an email from the (former?) proprietor of Xevo today, which included the instructions, with full color photos! Should have asked about left over parts at the same time.
Thanks!
Jim
monkeyracing is offline
Old 10-15-2011, 02:20 PM
  #16011
Jim you don't need a copy anymore?
Old 10-15-2011, 04:29 PM
  #16012
Nope. I've got one now. Do you need one?
Jim
Old 10-15-2011, 04:35 PM
  #16013
Jim
No. I asked the Xevo distributor and got a copy for you. Lol
Old 10-15-2011, 05:12 PM
  #16014
any last min. advice on building a spec m-05?
hotrod306 is offline
Old 10-15-2011, 05:31 PM
  #16015
j.d.roost's Avatar
Trader Rating: 32 (100%+)
What will stop a m05 from diffing out?
My car is very stuck and drives good.
I could not make it traction roll
if you paid me ...but it will lift the inner front tire on a hard corner
and unload the ball diff.
I have tried messing with oil and gave a rear bar a shot but it will
still unload bad and I loose all corner speed.
Only help so far has been a TIGHT diff. but I get too much push on corner out.
What should I adjust 1st,2nd,3rd ect...
current setup.
m05 pro
weight 1252
silvercan
ball diff with m03 cvs
Option front alum. tower with shocks in 2nd hole from center.
trf shocks 3 hole 45 front 35 rear,no orings/spacers in front shocks (full droop) 1oring in rear shocks.
front blue rear red spring
lower hole on the rear hub link.
spec tamiya premount rubber (tcs tires)
1/2 toe out front.
5mm front 5.5mm rear ride height.
High bite carpet,jack the gripper full front and rear
j.d.roost is offline
Old 10-15-2011, 05:57 PM
  #16016
Only help so far has been a TIGHT diff. but I loose all corner out.
current setup.
m05 pro
weight 1252
silvercan
1/2 toe out front.
Have you tried yellow or blue springs in the rear? You could also try an external o-ring on the rear shock shafts to limit compression in the rear. This may help keep the rear from dumping during hard cornering which could help keep the opposite corner front wheel from lifting up. One thing I keep seeing with these mini's is that if you have a problem on one end of the chassis, ALOT of the time it's caused by something being wrong with the opposite end.
nytryder is offline
Old 10-15-2011, 09:42 PM
  #16017
Ah! So it was a combined effort between your prompting and my email that got the job done. Perfect!
One way or the other, I have a .doc file now that I can add to the reference library. Now if only they'd cut me loose from this hospital room so I could go home and play with my new toy, life would be perfect. This place is boring and playing with Dremels and soldering irons is frowned upon.
Jim
Old 10-16-2011, 06:46 AM
  #16018
Trader Rating: 88 (100%+)
Hey guys, I have an interesting scenario and a few questions here. Yesterday I installed a ball diff in my MO6 and when I put it back down on the track, it acted like it was tweaked. it steered great to the right, but pushed like a dump truck to the left. Also, I noticed that when I installed the cvd's that you're supposed to run, that the dogbone is right against the diff nut holder in the outdrive. What side is the diff nut supposed to be on? Right now its on the left (motor side). Also, would installed the ball diff in backwards cause the car to feel tweaked? Or have I put something back together wrong? I plan on disassembling the whole rear tonight and putting it back together per the instructions, but I also would really like to use the ball diff. Thanks for any help.
MUDVAYNE is offline
Old 10-16-2011, 07:43 AM
  #16019
j.d.roost's Avatar
http://www.rctech.net/forum/9670021-post15699.html
I did it too...
Old 10-16-2011, 08:06 AM
  #16020
Cool, that solves one issue, but would this cause the car to feel tweaked?
MUDVAYNE is offline
