Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 06-26-2011 | 07:54 PM
  #15181
monkeyracing's Avatar
R/C Tech Elite Member
Have you tried this with a different servo or with the servo unhooked from the rest of the steering? Sometimes a servo will draw too much power and overwhelm the BEC circuit in the speed control, causing it to shut down.
Jim
monkeyracing is offline
Old 06-26-2011 | 08:21 PM
  #15182
Zac_with_no_K's Avatar
Jim
I haven't tried either. I will try both tomorrow, thanks.
Zac_with_no_K is offline
Old 06-27-2011 | 12:44 PM
  #15183
Fluffy622's Avatar
Originally Posted by caltek1
Find attached a Link to Tamiya USA website for Hopups for the MO5. I believe google can be your best friend.
http://www.tamiyausa.com/product/rcp...=desc&offset=1
In response to your question PNo 54182. Check link above for accuracy.
Regards,
Calvin.
Thanks Calvin. This might be a dumb question but will those ends screw on to my original parts I have or do I have to buy new parts that accept those new screws and ballends?
Fluffy622 is offline
Old 06-27-2011 | 02:18 PM
  #15184
caltek1's Avatar
Fluffy622,
They screw into the original parts. They just replace the one piece units. See attached photo's.
This is my MO5 Pro as I run now, Weighs in at 1350 gms, with battery and body and has 65gms of lead ballast. It has a ABR oil gear diff fitted using 500 000 weight oil. Other than that, all hopups are tamiya, except the outer motor heatsink, which is 3Racing. Our mini class weight limit is 1330gms ready to run. I do not mind taping the battery onto the mounts.
It has Ride 60D front tyres with Cross rears.
Later,
Calvin.
Attached Thumbnails Tamiya mini cooper-dsc_0278.jpg   Tamiya mini cooper-dsc_0281.jpg   Tamiya mini cooper-dsc_0282.jpg   Tamiya mini cooper-dsc_0283.jpg   Tamiya mini cooper-dsc_0284.jpg
caltek1 is offline
Old 06-27-2011 | 02:45 PM
  #15185
how did it work?
dacian is offline
Old 06-27-2011 | 04:14 PM
  #15186
Fluffy622's Avatar
Thanks a lot for the help and photo's calvin. I just ordered them . Another question for ya, does that aluminum steering linkage and rod tighten up the steering? I have like a 1/2in of play in mine.
Old 06-28-2011 | 12:11 AM
  #15187
James khoo's Avatar
+ YouTube Video
My local fun race at parking lot.
I qualify 4th,finish 2nd with my MO5 pro.Take off RP tire 36r
team power silver can motor.
James khoo is offline
Old 06-28-2011 | 01:45 AM
  #15188
Mr_Gleeman's Avatar
Congrats on your 2nd place finish there James, now pass me over the vertigo pills please
I think somebody needs to teach your camera man how to hold that video camera a bit more stable!
Talk about dizzy lizzy
Mr_Gleeman is offline
  #15189
Originally Posted by dacian
how did it work?
Unfortunatly, I didn't have enough time to mess with it today. Tomorrow I'm going out of state for 3 weeks..
Old 06-28-2011 | 02:08 AM
  #15190
James khoo's Avatar
Thanks,and yes the cameraman hand are not stable,but watchtable.
Old 06-28-2011 | 03:31 AM
  #15191
caltek1's Avatar
Fluffy622,
Yes the alloy steering rack does eliminate most of the steering slop. The one fitted to my car is the complete Tamiya set, which comes in three packets or you can purchase either the Yeah Racing or 3Racing versions. There is a Venom set which is just rebadged.
Never take all of the slop out of your mini or you will have an evil handling car.
I do rate the steering upgrade though.
Have fun and enjoy your mini racing.
Calvin.
caltek1 is offline
Old 06-28-2011 | 09:52 AM
  #15192
Fluffy622's Avatar
Thanks again Calvin! I ordered the whole thing from Tamiya today. I hope I get it in and on by Saturday. We have a special event at my local track. We are going to do a 30 minute main where half way through we have to do a tire change and a driver change. Should be fun!
Old 06-28-2011 | 01:42 PM
  #15193
flat4's Avatar
Default its gotta be easier...
I completed getting my mo6 pro put together, the camber is way off on the thing. I can adjust the front just fine but the rear end seams to be really busy were I should be adjusting the camber. What would be the easiest way to do this with out taking the camber rods off?
thanks Dave
flat4 is offline
Old 06-28-2011 | 03:02 PM
  #15194
thanks Dave
The camber should be close when assembled per instructions. Did you cut off 2mm for each ballcup for the front links? See top left pic on page 12.
There's no good angle to adjust the rear links. I remove the rear shock tower to adjust the rear camber. If you keep popping off the links, the ballcups stretch and create more slop.
Sydewynder is offline
Old 06-28-2011 | 07:47 PM
  #15195
flat4's Avatar
thank for pointing that out, we know what I am doing this evening
flat4 is offline
