Tamiya Ta06
#1261
red quite honestly I have not been to my track yet w the car. But from experience I can tell you its slow and that I would be a total road block. My mini-z seemed to have more punch.
The track where I plan to race has long straight and some pretty technical bits. I can def benefit from a car with some good acceleration and moderate top end. My driving style is usually to not use the brakes in the infield unless I HAVE to, and just a light tap at the end of the straight. (this is true for nitro and mini-z) I am sure 10th tc will be different. But my ESC has dynamic brakes, so maybe I wont use brakes at all. It is going to be a learning process with this car and electric overall.
I do however wanted to have enough gears so that when I go to the track I can happily run the car and start to tune.
About suspension,
The springs in the kit are MED. Anyone using Hard or soft?
both of the track I plan to run are concrete. On the tennis court the car felt nice, but I am sure once I bring it up to speed things will change.
About suspension,
#1262
Tamiya makes two different sets of springs Soft set (3 rates)
and Hard set (4 different rates)
As for as I know (and comparing the kit supplied White w/ Yellow Med spring)
it compares to the Med Yellow Hard set in this kit:
http://www.tamiyausa.com/product/ite...oduct-id=53440
(nevermind the outdated black and white photo)
From that kit, you have red, softer, and blue stiffer, and other white, more stiffer.
I have a set that I bring with me to an indoor carpet track, but, have not used anything other than the kit springs.
I drove an RC car on the High School tennis court once, lots of grip, but really upsets the P.E. teachers!
As far as gearing in your application, I would probably start with the 28t, (from the 28 and 29t set) A safer approach (as per your manual with the motor) would be to start with the 26t (from the 26 and 27t set)
Check the motor temp after a few minutes, and the length of a race, and adjust according.
#1263
For the stock pinion included.....find someone at the track with a TT01 or Mini....they might want that pinion.
#1264
New body, PF MazdaSpeed6.
Just finished the paint, hood graphic is hand painted.....old Testor's model brush.
Drove the new car in (2) separate mains.
1st drive of the new car in main, placed 1st.
Following week, 2nd run of the car in main, placed 1st.
Nice car out of the box, but......
The other TA06 at my local track has a few more runs on it.....I'm guessing, 10 runs....and the main belt is REALLY loose. To the point, that you can't adjust any more on the tensioner (which was never set tight to begin with) To the point, that it can easily be removed by hand. The front belt has loosened also.
Since mine only has a couple runs, it hasn't developed this issue, but I can compare the two side by side, and the difference is obvious. (I built both cars, at the same time)
My TC5 belts haven't got this loose, in over a year's racing. Do these belts suck? <or> is something else the problem?
Anyone else having belt issues? Both cars are running 13.5 BL.
****I am an idiot. I circled the wrong screw! its the blue screw in the picture.
#1265
I WAS going to race RCGT, but I have decided to stick to rcdrifting (eventhough I am the only one in CFL that drifts....)
#1266
Here is a 107 pcs hex screw set that is steel/chrome for 1/3 the price of titanium.
the main benefit of Titanium is weight with strength slightly compromised. steel/chrome is just as heavy if not heavier than the stock parts.
#1267
A few had this issue. Check your center pulleu(up front) it has a tendency to back the screw out and causing it to angle out. fix: Longer screw (10mm or 12mm if i am not mistaken) and a nut fastened to the bottom. or hop up to the eagle racing parts. It fixed my issue.....
#1268
#1270
#1271
what is a "TRF rear damper cups " how does it give you the flexibility to run other springs? dont the plactic do the same?
I was going to race rcgt, but I am now going straight to Touring HA! When I get my serpent then maybe ill move it into Tc and keep the TA for Tamiya cups and rcgt. (although there is people here running TRF41X for rcgt..
#1272
Just got the new Carbon reinforced A, J, and T parts as well as the front carbon damper stay:
http://www.speedtechrc.com/store/ebp...catmainid=1045
#1273
#1274
Both of the chassis I have listed are made specifically for drifting w/ the exception to the TC-FD which comes with all pulleys for either one minus the CS stuff unfortunitly... I am not saying this chassis will not work but what it will take to match the Tamiya VDF - just buy the VDF... Either way wrong thread for this debate
I am sorry but no one is going to notice that little bit of difference in weight unless you are a factory pro driver such as Marc Rheinard... $70 vs $21 for hex over philips is a positive in my book. If you are going to race in RCGT/USGT/VTA you need the added weight and the minimum is set so high.
Of if you are like myself and plan on upgrading to graphite the VBC Chassis kit comes w/ the hex screws already. I am just waiting to see what Exotek is coming out with before I decide.
I strongly disagree. I have been rc drifting for 6 years now (started out with a yokomo) and this is BY FAR a better chassis. more balanced and the response is unmatched. only issue so far is countersteer drifting. no one has made kits, but when (if) they do, the only mod can impact the front being as how the rear are gears that cannot be adjusted...there is a company that is coming out with Ackerman steering set for this chassis. too bad its $100.
