Tamiya Ta06
#1022
It was never designed to compete w/ the likes of HB TCX/TC6/Xray etc. That is what their TRF416/TRF417 are for
I am sure it will make for a great starting point for you or to be raced in VTA/USGT etc.
What I really like about this car is the centralization of everything. Only two other cars offer this and one is discontinued the other (TM ER4S) is hard to come by for parts due to overseas. With that said the same company is ditching it's 3 belt design/centrailized in favor of 2 belt standard design such as Xray/TRF417
#1023
#1024
sold my ta05, is the ta06 worth the money or should i get the ta05 ver 2, or get something else, i read the entire thread, and some say its a good car while others say no, i will be racing it in the gt2 catagory, black can motor, so which car should i get thanks
#1025
Some were very fast with a S710, I had some it was a good car, but I certainly did much better with my MTX4. Not sure if its the same in electric, but I am it is. Also Bodies make a difference.
So far I am liking the kit, but I am disappointed in the bearings. I though they would be rubber sealed like what I was used to seeing on my nitro cars?
How am I supposed to clean the great our of these metal sealed bearings? - do you guys at all?
#1026
http://tamiyaasiacup2011.blogspot.co.../gt-class.html
The white one's you've seen are probably Xenon spurs... 64p
#1028
TA06 feels to have the snap of a shaftdrive but remains forgiving like a belter
although i like shaft transmissions for their efficiency in lower-power classes
these days with lipo+BL i don't think there's any marked differences
#1029
and the higher-end chassis would be blessed with them... would've been
up till TB EvoIII Surikarn & TRF414M2 then they stopped giving them.
Now everything gets the ordinary steel sheilds probably of some cheap china origin.
I use tip of knife to lift the pointy end of C-clip.
You can take out 1 or both sides.
most grease lately don't seem too easily sprayed out with motor spray
so i soak them overnight in hot water with dishdrops or truck degreaser.
Usually do in a large batch, oil them when ready for use.
#1031
bearings don't last forever, these days they're throwaway cheap
(i don't bother buying fancypants ceramics or exotic ABEC10,001 etc)
don't really have to open them, i also use an RPM Bearing Blaster
and shoot thru motorspray (brake cleaner even better) & compressed air
just takes a bit more labour than boiling the whole batch in sudsy water
#1033
I have a "jewelry size" ultrasonic cleaner.
It doesn't rate a mention 'cos it doesn't really work any better than just
giving your parts a scrub with an old toothbrush, faster too.
Some ppl fill the ultrasonic with mineral solvents... highly unrecommended as
the ultrasonic will vaporise the flammable liquid and fill your room with vapour,
just waiting for the next tiny spark to happen.
Degreasing bearings, lazyman's way with least effort is to boil them in
detergent/degreaser and let them soak a few days then rinsing.
Could soak in any solvent eg turps, acetone, petrol, naptha etc
but its still not as fast as hot detergent.
Tabletop parts washer would be best, but i haven't found
enough excuse to buy one to try yet
#1034
how to clean bearings:
1. get a film canister (the old cylindrical containers used to store film way back when cameras didn't have slots for SD cards)
2. drill a small hole on the cover
3. dump all your bearings in the container and cover
4. with your rc cleaner/brake parts cleaner or whatever solvent you use, insert the straw or nozzle through the hole and spray a liberal amount into the cylinder. fill 1/3 to 1/2 full.
5. with a towel pressed down by your finger against the hole, shake the can like you were making a margarita (accompanying music and dance moves optional).
6. when your tired from the shaking and dancing, stop, drain the fluid and let the bearings out.
#1035
