Tamiya Ta06
#1923
need help setup for carpet
Guys...
I'm running tcs with 13,5 brushless on semi grip carpet...
I'm having problem with under and oversteer...
My setup is:
Front
300k gear diff
35wt oil + blue spring
Shock position std
Camber 2*
Toe out 1*
Droop 5
Ride height 5
Rear
7k geardiff
40wt oil + white spring
Shock std position
Camber 3*
Toe 2,5*
Droop 6
Ride height 5.5
Tyre is sorex 24r with medium insert and also try tamiya type c with medium insert
Please help me out..
Thanks in advance..
My setup is:
Front
300k gear diff
Shock position std
Camber 2*
Toe out 1*
Droop 5
Ride height 5
Rear
7k geardiff
Shock std position
Camber 3*
Toe 2,5*
Droop 6
Ride height 5.5
Thanks in advance..
#1924
Guys...
My setup is:
Front
300k gear diff
Shock position std
Camber 2*
Toe out 1*
Droop 5
Ride height 5
Rear
7k geardiff
Shock std position
Camber 3*
Toe 2,5*
Droop 6
Ride height 5.5
Thanks in advance..
My setup is:
Front
300k gear diff
Shock position std
Camber 2*
Toe out 1*
Droop 5
Ride height 5
Rear
7k geardiff
Shock std position
Camber 3*
Toe 2,5*
Droop 6
Ride height 5.5
Thanks in advance..
#1926
Ok°, I will change the sping and will see what is going to happen...
But I'm no sure what do you meant by removing front toe? Do you mean make the toe 0*?
I use original suspension mount setting which is 0* but I add 1* on the toe..
#1927
I am interested in purchasing a ta06 pro, couple of questions, does anyone sell a stainless steel screw kit, or where can you purchase allen head aluminum screws in the 3x48 size they are so long, also what idler are you using to replace the kit gear with thanks
#1928
The toe is adjusted by lengthening the turnbuckles that attach the steering knuckles to the steering link. 0* means the front tires are parallel to one another. Never run toe in (front of the tires closer together that the back of the tires) on the front of the car. If your front toe is 1* out it causes the car to initiate a turn easier but can cause it to hook sometimes, so as suggested give 0* a try. You could also try dropping the dual rate on your radio to see if it is just a little oversensitive to your driving style.
#1929
Does anybody know a good place to pick up a ta06 pro kit stateside? Preferably California?
#1930
I ordered the ta06 pro, and wanted to get the 2007 nsx body, does the rear shock tower fit or is it too high for the body, I know the front uses the ifs setup, but not sure about the rear, will the ody clear the rear as well thanks
#1931
k4, try going thinner on your rear gear diff, I'm running 3k, which works awesome. Also, try a spool up front, even though it feels locked down with the 300k, it will still unload slightly, the spool makes it a blast to drive, as you can really power out of the corners.
As far as the toe, I'd leave that alone, I run 1.5 deg. toe out on mine, and works well. I'd run the 40wt oil all around and keep the stock white (yellow) springs all the way around. Silver sway bars front and rear will work great too.
#1933
#1934
#1935
We should have some coming by the end of this week. I can save it for you if you want!
