U.S. Vintage Trans-Am Racing
#1306
How is everybody achieving the FDR for running 17.5 brushless? So far the lowest spur i can find for my JRXS is a 118 so in order to achieve a 3.6 FDR i would need a 59 tooth pinion which i dont think anybody makes or i cant find one. And if i decided i wanted to run my pro4 the lowest spur i can find is a 88tooth and once again i would need a 59tooth pinion. Is it really possible to run that low of an FDR?
#1307
Yes, very possible.
For the Losi, get a hold of the PRS spur gear adapter that will allow you to run standard spur gears. That will make your life easier. It will keep you from having to run 60t pinions—which PRS also sells.
Shaft drive cars are a little more difficult to do, because of the taller internal gear ratio, but it can be done. We ran 86t spurs on a TC3 with big pinions to get to the proper ratios.
#1310
We have Vintage Tires back in stock:
http://hpiracing.com/products/en/4797/
http://hpiracing.com/products/en/4793/
We will also re-stock the Slick Vintage tires soon:
http://hpiracing.com/products/en/4792/
http://hpiracing.com/products/en/4791/
We we're a little caught out by the increased popularity of the Vintage class, and have adjusted future inventory quantities for the Vintage items.
In addition we are also creating a special events inventory "stash" for the Vintage items, so as to create a buffer of the must have "spec" items. So if anyone's trying to get stuff for a race or any organizers/shops out there are sweating it for a particular event....drop us a line and we will try to assist you in locating Vintage items ([email protected] HPI Vintage in the email description)
Thanks,
AH
hpiracing usa
Thanks,
AH
hpiracing usa
#1311
Thanks,
AH
hpiracing usa
Thanks,
AH
hpiracing usa
#1312
Now THAT is factory support! Very cool, Andy. I'm thrilled that HPI is behind this as strong as you guys are.
Now, about that AMX Javelin...
#1313
About the Javelin. I know someone that will be thrilled to know that the founder of the Vintage TA Class is interested in a Javelin shell. He keeps asking everyone to keep an eye out for them.
We should compile a list of all of the cars that were ever in the real TA races and then poll the racers to find out which ones we would like to suggest to the Manufaturers.
#1315
Andy is the man. If that doesnt let you know that HPI is paying attention, then I dont know how to help you. Thanks again Andy and HPI.
enough said
#1318
Yes, very possible.
#1320
Anyone else thinking Vintage Drag racing?
http://www.midwestgassers.com/chariots.html
