U.S. Vintage Trans-Am Racing
#9346
[QUOTE=LOSIRACER77;8048069]
Give this setup a try.
FRONT
Ride Height - 5mm
Droop - 1.5mm over ride height
Caster - 4*
Camber - -1.5*
Toe - 0*
Upper control arm - E
Shock location - 3B
Springs - HPI Pink (15.2#)
Oil/Piston - Trinity30/2 hole
REAR
Ride Height - 5mm
Camber - -1*
Toe - -3*
Upper control arm - C2
Shock location - 3[color="Red"]A
Springs - HPI Orange (12.1#)
FRONT
Ride Height - 5mm
Caster - 4*
Camber - -1.5*
Toe - 0*
Shock location - 3B
REAR
Ride Height - 5mm
Camber - -1*
Toe - -3*
#9347
[QUOTE=2xs;8048590]
FRONT
Ride Height - 5mm
Caster - 4*
Camber - -1.5*
Toe - 0*
Shock location - 3B
REAR
Ride Height - 5mm
Camber - -1*
Toe - -3*
Thank you man!
FRONT
Ride Height - 5mm
Caster - 4*
Camber - -1.5*
Toe - 0*
Shock location - 3B
REAR
Ride Height - 5mm
Camber - -1*
Toe - -3*
#9348
Most of the time we have only rubber tire classes and a groove comes into the track it does not take it away.... so that's not true. However if you end up with foams to keep the peace that's your guys decision there... have fun and race.
As far as foams go we have had some guys for enduros take their VTA cars and put foams on them. Usually they were hard nitro foams and they worked well with the rubber setups on the car. As far as offset foams I don't know of any but I'm assuming you are looking at that for the "look" of the cars. Well the HPI Mustangs are narrower in the rear so they will look fine with no offset. The Cuda and Camaro are wider in the rear but you could always just widen the rear with wheel shims if its that important. You really won't have the vintage look anyway so I personally wouldn't worry about it.
#9349
P.S. Since I have not run 1/10th at all I am assuming that the drive hex size is 12mm? Looking at the tires they look smaller than my stock t-maxx 14mm ones
#9350
Gear diff in VTA?
Just curious if anyone has tried one in VTA? Maybe in the the front? It would act more like a spool, but have some give to it? Do these 25t have any power to put down? I've not tried a 25T yet. I have to buy a diff anyway, so I figured a gear diff would be cheaper.
#9351
Traxxas 4-Tec
I have an old electric 4-Tec and wanted to know if the chassis would be legal for VTA?
#9354
After watching you guys on Sunday(I was the guy racing the Inferno GT2), it seemed like fun and since I have a chassis, i should be able to get into it pretty cheap! Any good motor/esc combos you'd recommend?
#9356
Company Representative
Here is the link to our USVTA store that showcases all of our customized products (including factory re-manufactured items):
TeamNovak USVTA Store
#9357
Thanks for the link, will the motors drop in my 4tec or will an adapter be needed, and this goes for any of the VTA Spec motors?
#9358
you might have to play with gearing to find something that works, but that shouldn't be too much of an issue
just remember, you now will have 3 wires going from the speedo to the motor (instead of 2) as well as the sensor wire - so plan accordingly
#9359
