Hpi Pro 4
Originally Posted by STILL BURNING
Does any one have a set up to suit a pro4 with foam tyres. I can not get mine to settle the rear end
Anyway... try to Setup your car on the Manufacturer's settings first and try to do some practice on that setup... after wards you will want to adjust either on the aggressive way or more safer way.
I did it but it was too safe for me... so I did some more aggressive moves with my Car...
You know the Upper Deck?... I Sliced it into two to give it more Flex and I dont use the stiffiner that you screw in the middle between the lower and upper decks. Plus made some big Holes rectangular Holes in the Chassis... to lighten it.
Go ahead start from the Manufacturer's setup and adjust according to your driving needs...
But I am just one guy to give you pointers... some are more systematic with their setup... try to ask around more...
Originally Posted by cyclone
hi thanks for the help, im running a front ball differensial, so putting in more shims on the front should cure this then?
will this mean that my bevel gears will be ruined?
cheers
andy
cheers
andy
Plus check the Bearings, if it has a rough Feeling when you spin it... replace it... all bearing should be properly Oiled and free from rough spinning. that is one factor for noisy performance when releasing from throttle.
well... I hope this side of the story helps... be open for all comments and tips...
Cheers!... go race more to learn new facts for your driving style.... there is no such thing as 1 type of Setup.
here's my frist electric onroad racer
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG][IMG][/IMG]
Does anyone have good set up for socal ?
Other than the one on hpi website. thiking about racing there this week end.
Super Moderator
try this one
nice
cash-money: I like ur ride... looks nice...
Hey guys,
You can post pictures of your cars on the HPI/HB thread located at the team company discussions forum. Let's see all Pro4 cars there.
checkout my jdm japanese carbonfiber driveshaft and my new monster pro 2
when are you guys gonna race/pratice at socal?
the carbonfiber shaft is from hpi japan only
could somebody please remind me of the hpi spring rates please? red blue yello white silver gold and pink...
thanks alot
thanks alot
Hi cyclone,
Here are the rates of HPI springs:
Copper - 147gF/26mm
Silver - 154gF/26mm
Red - 238gF/27mm
Gold - 200gF/26mm
Orange - 216gF/27mm
Yellow - 227gF/27mm
Green - 247gF/27mm
Blue - 264gF/27mm
Pink - 272gF/27mm
White - 298gF/29mm
Hope this helps.
Copper - 147gF/26mm
Silver - 154gF/26mm
Red - 238gF/27mm
Gold - 200gF/26mm
Orange - 216gF/27mm
Yellow - 227gF/27mm
Green - 247gF/27mm
Blue - 264gF/27mm
Pink - 272gF/27mm
White - 298gF/29mm
Hope this helps.
Super Moderator
thanks alot
thanks alot
HPI springs
Blue -15.3 lbs
Silver -16.9 lbs
Pink -18.0 lbs
Gold -19.0 lbs
White -20 lbs
Yellow - 21.7 lbs
Red -22.4 lbs
