Hpi Pro 4
#5161
Originally posted by Downforce
There is no TOTAL toe. The toe is per side. 3 degree block is 3 degrees per side AND NOT ADDED. The way you guys are explaining it. You could have 2 degrees on the right and 3 on the left for 5 degrees. That is wrong.
(just an example---->)And 2.5 on the right and 2.5 on the left is not 5 degrees. It's just 2.5 degrees.
Example:
With the 3 degree Toe Block installed, measure EACH side of the Car with a Hudy/Integy Set-up gauge. EACH side will measure 1.5 degrees, for a TOTAL of 3 degrees. The 2 deg block would give you 1 deg per side.
#5162
Re: Re: Purple motor heatsink
Originally posted by rc-zombies
Integy or Ebay
Integy or Ebay
#5163
Originally posted by Super Steve
lol, did you buy your car prebuilt?
Cheers,
Mossie
#5164
Registered User
#5165
Erik,
How did you make the spool?
#5167
Originally posted by Aku-Man
Just ordered camber link holder. They look better than Square's.
Jet Racing for Pro4
Jet Racing for Pro4
Hope they have them instock already... I ordered a set this morning...waiting for their reply...
#5168
Registered User
I don't order direct from Jet Racing. Their price quote is bit higher than other store.
#5169
Originally posted by popsracer
NOT!
Example:
NOT!
Example:
I just measured mine using the RPM camber guage. standing the car upright..it measured out to 2.5degs. each side (2.5 pivot blocks in the rear) Time to pull out my Integy Set-up gauges and double check....
#5170
What makes them better?
#5171
NOT!
Example:
NOT!
Example:
#5172
#5174
Pops must run a Losi. Cause thats how they measure it. They measure total toe in by adding the two side together.
#5175
NOT!
Example:
NOT!
Example:
