Like Tree86Likes
Hpi Pro 4
Old 03-15-2004, 03:02 PM
  #2356
Beeb's Avatar
Originally posted by rc-zombies
That blue motor heatsink has to go... j/k
a purple one is available from Integy.
Yeah, I know but my LHS only had the AE one and I had to have one that very second.
Beeb is offline
Old 03-15-2004, 03:06 PM
  #2357
The Evicerator
Nor you Erik, you're both FABULOUS!
Steve Weiss is offline
Old 03-15-2004, 03:32 PM
  #2358
SpeedTech's Avatar
Hi Guys,
The ceramic bearings are in, I will setup the Pro4 ceramic bearing kit tonight. Thank you all for your patience.
Steve Wang
SpeedTech is offline
Old 03-15-2004, 05:09 PM
  #2359
RCBuddha : I'll be at Socal on this coming Sat. Want to go over some setups with you. BTW....what setup are you running at Socal?
Thanks,
Jeff B
Proteus is offline
Old 03-15-2004, 05:48 PM
  #2360
RandyB's Avatar
hey steve do you have the tobee main shaft?? and how close does their anodize match the hpi purple??
RandyB is offline
Old 03-15-2004, 06:21 PM
  #2361
blast's Avatar
Trader Rating: 28 (100%+)
Originally posted by SpeedTech
Hi Guys,
Steve Wang
whats the price on those sets?
blast is offline
Old 03-15-2004, 06:28 PM
  #2362
blast's Avatar
the 3 degree in the rear is to much for a wide open track.
still end up in A main 3 rd. place came up from way back.
blast is offline
Old 03-15-2004, 08:25 PM
  #2363
Here are some pics of my chassis from the side. Pic 1 shows it flat on its side. Now pic 2 shows it when I push down on the rear left of the chassis (right behind the battery brace). The pictures aren't the best, but you can see the chassis rise a bit. And I've been trying every which way to tighten down the chassis and upper deck screws. I'll have to see if CA'ing the shock towers and motor cutout does anything (only did the outer chassis).
dreambrother is offline
Old 03-15-2004, 08:26 PM
  #2364
Second pic:
Old 03-15-2004, 08:35 PM
  #2365
rc-zombies's Avatar
I have the tobee shaft drive cups..the ano is closer to pink than HPI purple.. don't know about the other Pro4 tobee parts...
rc-zombies is offline
Old 03-15-2004, 08:46 PM
  #2366
AMGRacer's Avatar
Anybody having trouble with their chassis tweaking? I saw one on the weekend where you could badly tweak the rear wheels by twisting the car in your hands. Tried loosening the screws, tightening them in the right order etc.
AMGRacer is offline
Old 03-15-2004, 09:08 PM
  #2367
R/C Tech Elite Member
RCBuddha's Avatar
Trader Rating: 40 (100%+)
Thanks,
Jeff B
Hi Jeff,
Would you believe that I was there last saturday, and forgot to ask who you were!
Not a problem, I'll be there on saturday, bright and early. I should be running Sportsman, I got whipped pretty good in 19turn last weekend.
SoCal setup:
Fr:
50 wt
#3 piston
stock shock positions
Droop: 4
I took away a 1mm spacer from the camber links, to raise the roll center
RR:
50 wt
#3 piston
Droop: 5
Stock shock positions
I lowered the roll center by adding a .5mm shim to the camber links
Misc:
Sorex 36R w/ yokomo medium thin inserts
camber: -1 all around
0 toe
The car was awesome in practice, but during the main, the rear started to break traction. I think it was the tires though, and I'll be trying some 32's instead. I'm going to play around with the setup some more tommorrow night, so i'll let ya know how it works...
Buddha
RCBuddha is offline
Old 03-15-2004, 09:14 PM
  #2368
RCBuddha's Avatar
Try this dreambrother:
Loosen ALL the top deck screws, including the two in front of the shock towers. Put your racing batteries in, and secure down with the battery brace or tape. Then tighten...see if that makes a difference. I don't think it'll be ABSOLUTELY perfect, cause mine isn't.
Buddha
RCBuddha is offline
Old 03-15-2004, 09:37 PM
  #2369
Originally posted by RCBuddha
Hi Jeff,
SoCal setup:
Fr:
50 wt
#3 piston
Droop: 4
RR:
50 wt
#3 piston
Droop: 5
Misc:
0 toe
Buddha
Thanks for getting back. I was pitting near Jose last weekend. I ran sportsman stock....white/blue vauxhall vectra
I think I've been chassing setups using the same sorex 32/green inserts that I've been running for the past 2 months. This weekend I'm going to try 36's with thin inserts and some CS32s (any luck with the takeoffs?).
Basically....I run
Front: #2 piston 40w (losi)
AE Blue springs
roll center: 3.5mm
camberlinks in stock position
NO swaybar
Rear: #2 piston 40w (losi)
running slight anti squat.....5mm shim on the F block
AE silver springs
roll center 2.5mm
shocks...all the way out on top/bottom mounts
camber links: all the way out on both inside and outside mounting positions.
I'm going to try a 2.5 rear block to take some toe out. I know it's not much but we'll see. I'm also going to switch to 50w oil all the way around
JeffB
Proteus is offline
Old 03-15-2004, 09:57 PM
  #2370
RCBuddha's Avatar
Hi Proteus,
I DID see your car run, it looked really good.
Your setup looks good, i'll give it a try tommorrow... I'm going to try some old tc3 setups i have, to help get a starting point.
Which reminds me: WHY isn't there an editable Pro4 setup sheet????
As far as the tires: I've had really good luck with 32's and thin inserts, the greens tend to overheat the tire and make it slippery later in the run. I haven't tried the take-offs, but some say that the Yokomo 139's hook up ok.
SoCal can really change rapidly, the traction can be great during open practice, but once the temps drop, everything gets slippery.
Buddha
RCBuddha is offline
