Hpi Pro 4
#2341
Thanks Buddha
#2343
#2347
Downforce: The Losi hubs need to be reamed out a bit. I used a 7/16" drll bit as it was all I had. Not the best though, it was a little big. The grub screw took out the slop mostly, but you might have to try a wire sized drill, they have a finer sizing. MIP losi or AE axles fit right up to the HPI bone. You will need the Losi bearing, it is an English measurement. But i have switched to an evoIII block........
Also the EVOIII "b" block will give 1* of toe when used in place of the rear f/r block. The block is 2mm taller than the HPI, so I did remove 1mm of material with a file. Hara's seup uses a 1mm spacer under the mount so that was good. It came out really good, i just took my time and kept measuring both sides on a glass table to make sure it was even and flat. The "c" or "d" blocks should give even less toe, which could be helpful for the front.
#2348
I think it's about time i get me a Pro 4 and stick with my TC3 and in the making TC3 And i'm only 14
#2351
Originally posted by AWOLsoldier
What does you being 14 have to do with anything?
#2352
Well, here's my pro4 at the moment. I'm still waiting for a battery to arrive and get the body painted.
