Best charger of all time?!
#166
I finally got my chargers . Waiting for my 30 new battery packs ...
#168
Here is the new Orion charger.
• Charges 1 to 8 cells stick/saddle/receiver/transmitter packs
• Nimh/NiCd compatible
• Adjustable delta peak, mAh or temperature charge cut off
• Discharge function adjustable up to 10 Amps
• Motor run in and comm lathe power supply feature
• Input and output short circuit protected
• Silicone wiring
• Linear charge mode
• Battery cycling possibility
• Trickle charge function
• Error function display
• Indigo blue back light
• Customized username input
• Choice of 3 melody's or whisper mode
• True internal resistance measurement
• Ultra sonic magnet temperature probe
• Adjustable pulse charge mode
• 3 charge/cycle memory storage
• Clock with stopwatch/lap counting mode
• Adjustable English, German, French or Japanese language modes
• USB port with free downloadable software for perfect battery management
• Removable stick pack "free air floating" battery holder
• New high tech step flex charging function
• Super easy to navigate and set-up with our "easy 2 charge" menu
• Silicone wiring
#169
Don't know where else to put this but I have the turbo 35 BL and it seems the *&%%^^^%^& 20 AMP fuse keeps blowing out when I run the discharge or cycle mode Any one else have this problem?
#171
I don't get some of the new chargers coming out. They either have 10-20 amp discharge or no motor run. Haven't they learned from Competition Electronics that we need 30-35 amp discharge,motor run and a great charge.
#172
Nova,
Prob have to send it back to CE. It shouldn't be doing that. There repairs are very reasonable and fairly quick.
#173
Originally posted by roaddog
Nova,
Nova,
#174
Originally posted by Nova F1 Racer
I'll have to call them tomorrow and see what they say...
Looking at an old manual it seems there should be 2 yes 2 20 AMP fuses in the holders in the base .... I looked and there was a 20 and a 15 now.... Guess what I'm swapping out when I get home After talking with him for 10 minutes I know more about this puppy then I did expected!!!
BTW the 2 fuses act in parallel so I bet after a closer look the 15 amp is blown and I have been running on the 20 amp all along...
And he mention that the latest release is 5.7... Cost $25.00...
#175
I wonder who makes the Orion Advantage...
#177
Is the intellipeak Digital Pulse Good?
#178
I just got a new Great Plains charger that does Ni-CD, Ni-MH, Lead Acid, and Lithium Ion. It charges at up to 5A and cycles up to 10 times in a row. Just set it and leave it works great.
