Tamiya TRF416 / TRF416WE / TRF416X
#2221
#2222
MY new shell and pit board ready for my TRF416 .
#2223
#2224
A guy called Graham here in the UK painted it all for me.
I just sent him the ideas i had and what i wanted in the design.with the Tamiya logos etc. And i must admit im pretty shocked he,s done himself proud.
I also had a another shell paint in a subtle pastel colour scheme.
Heres a pic see if you like?
#2227
Here is Victor Wilck set up from the 2008 Reedy Race
FRONT
middle hole on tower
C front C rear flat
associated 40wt oil
2.5mm under camber link inside hole
5mm ackerman
.5mm bump steer spacer
HPI silver springs
No rebound in shocks
Droop 6
4mm he hubs no spacers
furthest hole on a arm
Rear
3rd hole out on tower
1xa front
1e rear
associated 40 wt oil
HPI blue spring
3mm spacer on hub outside hole
4mm hex hub no spacers
2nd hole oustside on arm
no rebound on shock
protoform mazda speed six
rear hub in middle
FRONT
C front C rear flat
associated 40wt oil
5mm ackerman
HPI silver springs
Droop 6
Rear
1xa front
1e rear
HPI blue spring
no rebound on shock
rear hub in middle
#2228
Rear Droop 5
#2229
Here is Hupo H set up from the 2008 Reedy Race
Front
middle hole on Tower
Tamiya 400 Wt 3 hole pistons
3.5mm under camber link in middle hole
Furthest hole on A arm
4mm hex hub .5mm spacer
416 D front and 416 d rear flat
HPI silver spring
5mm ackerman
droop 6
arm spacing 2 mm front 2mm rear
Rear
Tamiya 400 wt 3 hole pistons
3.5mm under camber link middle hole
3mm spacer outside hole rear hub
HPI Blue spring
2nd hole outside on a arm
4mm hex hubs
1xa rear front 1d rear
mazda speed 6 body
arm spacing 3mm front 1mm rear
Front
HPI silver spring
5mm ackerman
droop 6
Rear
HPI Blue spring
4mm hex hubs
mazda speed 6 body
#2230
have Marc setup ?
#2231
Mark's set up is very close to Victor's Set up very very close
#2232
Need to add to Hupo Set up
Full rebound in shocks but nothing on top of bladder
#2234
I ran Victor's Set up all through Qualifying with just a few little changes but for the 3rd main I switched to Hupo set up and it was much better for me
