Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 05-03-2008, 10:56 PM
  #2071
bboy's Avatar
Originally Posted by patrick
BBOY, you didn't mention your droop settings, 3mm front and rear is a good starting point. Also I would change to 3 degree rear toe and 5 mm ride height. I assume your running a spool. if not, put one in.
I am running 1mm droop front and 5 mm droop rear.
Let me try the spool because my other problem is the car gets unstable with one-way when I brake.
bboy is offline
Old 05-03-2008, 10:58 PM
  #2072
bboy's Avatar
Smile
Originally Posted by TRFwhitey
bboy, make your life more simple and just try one of the setups posted on tryhards site. You will only have to make minor adjustments to suit your track or driving style.
jontang001, its an adjustment not too many people play with. I have tried alot of different shock adjustments at many different tracks. The effect of rebound directly impacts the way the car handles bumps and negotiates quick switchbacks(aka shicanes). I have found the more rebound i use, makes the car more responsive/aggresive but can handle bumpy tracks much better, less rebound the opposite is true. The reason why rebound works best for bumps is rebound keeps the tire in contact with the track after you hit a bump, the longer you car stays in contact with the track the more stable it is. As for shicanes your car needs to change directions quickly, so with alot of rebound your car will be able to transfer the weight L/R quicker with assitance from the rebound. For me i almost always run full rebound just because i like a responsive car and if there is any inperfections in the track my car will keeps its composure. Hope this was not to confusing!
Thanks. Will do. However any suggestions on how to pick which setup? There are quite a few and I am not familar with their driving style and tracks...
bboy is offline
Old 05-04-2008, 04:13 AM
  #2073
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by TryHard
As for the arms, depends on what setting you want. Hole 2 (which the one most tend to run in), is the outer most hole on the inner set.
ah crap. sounds like I put them on back to front
Originally Posted by veecee
Hey Craig. I started with the second hole when counting from the hub end of the arm. This is very close to the kit hole on the std arms so it's a good starting point. Looking forward to seeing your 416 on the track! Cheers, Vincent.
Did you see pics of the completed track?? it looks great! I'll be racing 19t now they are allowing lipos too, mod has too much wear and tear
CraigM is offline
Old 05-04-2008, 08:22 AM
  #2074
Not for me, but does anybody know the part number for the parts to mount a Tamyia stick pack in the 416 ??
Many thanks
Andyg01 is offline
Old 05-04-2008, 09:01 AM
  #2075
peterchia41's Avatar
Hi,
Would like to enquire if the TRF Dampers (Part # 42102) the same as the dampers provided in the TRF 416 car kit?
If there is a difference, whats the diff?
Thanks.
peterchia41 is offline
Old 05-04-2008, 09:24 AM
  #2076
Look on Tryhard's site the manual for the 416 is there with all the part numbers
Andyg01 is offline
Old 05-04-2008, 09:54 AM
  #2077
Manual: http://www.petitrc.com/reglages/tami...416_Manual.pdf
Setups: http://www.petitrc.com/reglages/tami...miyaTRF416.htm
Arn0 is offline
Old 05-04-2008, 04:04 PM
  #2078
veecee's Avatar
Yes the track looks awesome. Hopefully there is a practice meet this Tuesday!
veecee is offline
Old 05-04-2008, 04:48 PM
  #2079
pug 205 gti's Avatar
MR ED
How can i get one of those fancy blue transponders like the one that sits gracefully on you 416.cheerz
pug 205 gti is offline
Old 05-04-2008, 05:36 PM
  #2080
TryHard's Avatar
ahh... well the fancy blue transponder is an MRTCustom iPT. My old AMB stopped working, so I had it cloned, and now have two iPT's, one in the tourer and one in my mini, both running off the same number
However, I believe the iPT has now been superseeded by the MRT PTX (details here). Best bet is to ask Terry S over in the PTX thread on here, or send him an email via mail(at)team-mrt.com.
HiH
Ed
TryHard is offline
Old 05-04-2008, 05:49 PM
  #2081
Cheerz MR ED.Just one more thing.i dont have an amb to clone.does that put me out the picture with the little shining blue transponder?.
Old 05-04-2008, 05:51 PM
  #2082
TryHard's Avatar
I don't believe so, as MRT can supply the PTX with 10 or 20 pre-programmed numbers to select. Very clever little device
TryHard is offline
Old 05-04-2008, 05:58 PM
  #2083
MR ED im wanting a new lipo or two as i only have the orion 3200.I see your running 3600.s now, but you recommend trying the smc 4000.any others youve seen that are up to scratch? i aint seen any uk smc dealers and ordering from the states sucks as i always get slapped off customs..... but hk is good.
cheerz
Old 05-05-2008, 03:30 AM
  #2084
HappyHippo's Avatar
Has anyone the setup from MACH circuit in Heemstede (ETS race)
HappyHippo is offline
Old 05-05-2008, 03:58 AM
  #2085
HPZ
Default left right balance
hi guys i've been recently having trouble with the balance of the car. It would be able to turn left very smoothly , but turning right it would hook more suddenly and oversteer. My electronics are , KO2413 low profile servo, normal spektrum receiver, TC sphere esc ,a novak 13.5 and EP4200 6 cell pack.
i checked the alignment of the wheels, droop and tweak, so the car is mehanically in good order. Steering throw is also the same left to right. I initially thought that since the battery side was more 'front' heavy it would grip harder and snap to the right due to that, but i was wrong. I tested the car with just a 4cell pack (moved to the rear most position) and still the car snapped to the right harder than the left. Then i ended up placing 100g of lead behind the 4cell pack ( on the right side to balance the motor) and this made the feel of the car neutral from left to right.
Back to the 6cell with 100g behind the batteries and the car would snap right again
Sorry to bog it all down like this but my question is do any of you guys experience anything similar? if so how do you get around it?
HPZ
HPZ is offline
