Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 05-19-2008, 12:29 PM
  #2206
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by RC MARKET View Post
Good News !
& June release TRF416 Stick pack battery lower deck kit !
Hmmm... before IIC. The traction there may warrant a thicker chassis.
syndr0me is offline
Old 05-19-2008, 07:25 PM
  #2207
t4m1y4niac's Avatar
Originally Posted by CraigM View Post
you'd be looking at 15/83 in 48dp. That sounds a bit tall though, I run 9.4 with my orion 3.5
83T spur??? have tried use 80T and the spur hit the lower deck....
t4m1y4niac is offline
Old 05-19-2008, 10:31 PM
  #2208
CraigM's Avatar
Trader Rating: 34 (100%+)
Hrm, my 78t is fine. If 80 hits then you won't be able to gear it that tall because you'll need a pinion around 14t and wont be able to get the motor close enough to mesh properly - with 17/78 my motor screws are all the way up against the end of the slots. You could try switch to 64 pitch, Ed has the gearing chart on his site though I'm not sure if it goes to 11.3
CraigM is offline
Old 05-20-2008, 02:27 AM
  #2209
Superkarter's Avatar
I have a 82T 48pitch spur on my car and it sits just above the bottom of the chassis. I think you should almost be able to get a 83 tooth spur gear in there.
Although i did put a slight bevel on the chassis where the spur goes to allow it top fit properly.
Hope this helps
Tim
Superkarter is offline
Old 05-21-2008, 06:15 AM
  #2210
bmmer701's Avatar
Trader Rating: 17 (100%+)
hi just want to ask what will be the effect you put shims or wheel spacers? let's say front wheels are wider than the rear? what will be the effect of that? and in vice versa (rear wider than front). thanks
bmmer701 is offline
Old 05-21-2008, 10:41 AM
  #2211
Racing4Evo's Avatar
Why are guys choosing to use 48pitch?
Racing4Evo is offline
Old 05-21-2008, 03:35 PM
  #2212
CraigM's Avatar
For some reason, virtually noone in Australia uses 64p, so none of the stores stock anything but 48p
the spacers are quite thin so they adjust your track only subtly compared to the variations you can achieve using the toe blocks & your front track should never be wider than your rear. The effect of adding spacers to the front will be more stability but less responsive steering, while adding spacers to the rear will give the rear end more grip
Now I've got a question. My car is pretty well sorted, however I'm getting a bit too much body roll (the sides of my chassis are scraping). If I want to maintain the balance of handling but reduce the body roll should I use firmer sway bars or firm up the springs?
CraigM is offline
Old 05-22-2008, 10:18 AM
  #2213
Toughbeard's Avatar
reason 1: It doesnt break. great for old goof balls like me who cant mesh the gears well
reason 2: 415 is too quiet... I need to make noise...
Reason 3: Everyone uses 64.. so noone can borrow pinions from me and forget to return them
Reason 4: Life is so much simpler with less gear ratios to deal with
Toughbeard is offline
Old 05-22-2008, 12:11 PM
  #2214
RC MARKET's Avatar
RC MARKET is offline
Old 05-22-2008, 08:52 PM
  #2215
KoE
KoE's Avatar
which reminds me of corally assassin direct-drive mode..that thing was loud
KoE is offline
Old 05-22-2008, 09:46 PM
  #2216
t4m1y4niac's Avatar
ok thanks a lot for your response.....
Old 05-22-2008, 10:06 PM
  #2217
syndr0me's Avatar
I finally got the car working reasonably well on asphalt. I think most of my trouble was tires, and general unfamiliarity with asphalt. The Muchmore Sweep 28's seemed to take a pretty bad beating considering the fairly mild temperatures.
Anyway, I'm still running the stock arms. Are the short arms the way to go on asphalt as well? Do the long (stock) arms work anywhere? It seems like the short arms the the popular choice everywhere. I guess I should pick some up.
syndr0me is offline
Old 05-23-2008, 06:17 AM
  #2218
bigbutstupid's Avatar
i've tried the short arms twice and play around with the settings quite abit... but didnt really work out for me on asphalt. i only race on asphalt, and i feel that the standard arms are the best for me.
i use foams as we are allowed to.
anyone knows what does the centre oneway do to the handling?
bigbutstupid is offline
Old 05-24-2008, 01:10 PM
  #2219
Rogier's Avatar
Can anybody help me? I want to buy a 416, but the car is nowhere in stock. I prefer buying in Hong Kong (i'm in Europe) because of the customs. Nowhere in HK the car is in stock.. Any tips??
Rogier is offline
Old 05-24-2008, 01:25 PM
  #2220
pug 205 gti's Avatar
I can,t help you on finding a TRF416?
Ive found this 5 cell chassis i don,t know if it will be of interest to anyone?
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-662d_12.jpg
pug 205 gti is offline
