Tamiya F103 Forum
#1546
http://www.tamiyausa.com/product/ite...oduct-id=50505
http://www.tamiyausa.com/product/rcp...s&kit_id=84191
#1548
has anyone had any experience with Zac Project/Kawahara foams for f103?
http://d-drivesportsenglish.com/inde...roducts_id=430
#1549
Never tried them. I use Kevin Frewers donuts, they're cheap and good.
#1550
i would to but he hasnt answered emails so looking at other options
#1551
Not sure how his international shipping is,but his service here in the states is top notch.
Donuts wear nice and work good both on carpet and outdoors.
http://www.rc4less.com/index.php?cPa...6e07e316e6be32
#1552
hi, it's been a while since I dusted out my F103. Currently I've go O-rings instead of springs at the bottom front arm. Does anyone still use this set up or everyone reverted to springs? I also read something about spring on top setup but not sure how that is implemented. Would there not be too little room between the wheel and top swing arm? Oh, I've got the swinging top arm not the fixed type if that makes a difference. Thanks.
#1553
#1554
Hmmmm- never heard of using o rings instead of springs ;interesting wouldn't that make the front push?
#1555
Does any one know the size of the ball bearing in the F103, all bearing.
Thank you.
Thank you.
#1556
Front wheel bearings are the 850 times 4 type bearings.
Rear axle depends on what motorpod you are running
Stock motorpod are 1260 times 2 and the hight adjusable gearcase are 1060 times 2
Diff bearings are 1280 times 3
You can look it up in the manuals on the Tamiya site.
regards Roy
regards Roy
#1557
regards Roy
regards Roy
#1559
#1560
honestly, I cannot remember how it handled since it was such a long time ago. I first learnt of it from this forum when some driver won a big F103 event (apologies to said driver for not remembering your name and the event ) and then everyone found out that he was using this o-ring mod instead of the usual springs. I believe some cried foul play but was apparently OK'd by the organizers.
Last edited by one-nil; 05-10-2011 at 09:31 AM. Reason: spell check to ward off the grammar nazis
