GM Brushless
#1156
0.9 is in the window when you read the profile off the speedo, The software was updated Jan 2009
#1157
Suspended
I have some nice gda's out of version 1.9, you could test if they work.
#1158
Hi Guys
any one help me with a link or info as to where I can send my GM120 for firmwear up date
Thanks.
Thanks.
#1159
Has anyone else had an 'Error reading "setup.ini" message when trying to install the AN335SW sftware after installing the VCP Driver Kit.
It seems weird as i'm getting this off 2 different laptops, and i really need to get this sorted before sunday.
#1160
Dead Gm120?
My Gm120 in the last qualifier had a type of miss fire on throttle in the last minute of a 5 minute run, when I went out for my final the speedo did not beep and only a red led was on, everything worked except the throttle. I tried everything I can think of , but the setup button is not working also. Is it a repairable fault?
Alan
Alan
#1162
At the moment i have a very expensive piece of programmable hardware in my car i cannot programme
#1163
Has anyone got a copy of an older version of the si-labs software i could have, it appears to me there must something with the current version on the website for me to have the same 'error code' on 2 computers running different versions of windows (XP & Vista).
Hi!
Last day I set gm's software for my friend without problems
on very small netbook with winxp.
Before instal try turn off if you have antivirus software, check if your
windows is up to date, then download:
- soft for GM: http://www.graupner.de/fileadmin/sof...up_V1.3.6_.zip ,
- usb driver: https://www.silabs.com/Support%20Doc...2K_XP_S2K3.zip
(or go to https://www.silabs.com/products/mcu/...CPDrivers.aspx and click on VCP Driver Kit).
Unzip usb driver, launch exec file, then should start unpacking, and
ask something like that "install usb driver ble ble", just use YES button or NEXT.
When you connect usb device to pc, you should see some info, that
windows found some new device
Install GM software and try use it.
Older software for USB device is a little bad for new software in GM esc.
Try do it again.
Regards!
m.
ps: for older software in ESC like 4.9 use this: http://www.graupner.de/fileadmin/sof...p_01_01_05.zip
#1164
GM-Racing:
'high' rpm motors, similar to what the current red/purple one is in 13.5/9.5
#97297 BRUSHLESS PRO 17,5T
#97301 BRUSHLESS PRO 21,5T
#97303 BRUSHLESS PRO 13,5T
#97305 BRUSHLESS PRO 10,5T
Graupner:
high torque motors with an insane amount of power
#6564 BRUSHLESS SPORT 13,5T
#6567 BRUSHLESS SPORT 10,5T
#6568 BRUSHLESS SPORT 17,5T
#6569 BRUSHLESS SPORT 21,5T
both series are all new developed motors with changed internals, changed can, vertically mounted sensor socket and other cool features like a temp protection
if used with the new Genius Generation 2 speedo.
#97168 will be the 120 Gen2
#97164 will be the 90 Gen2
apart from sharing the same case the speedos are all new aswell.
The caps have been removed from the main curcuit board and instead of those you will get the small caps soldered to 2 wires so you can place them whereever you want in your car. (like in mine as you see on the pics)
it will have many new features, functions and even more potential.
again it's not an update it's a new speedo.
Graupner:
#1166
same case same weight (approx)
but with the caps now beeing seperated from the speedo you are a lot more flexible where and how to mount the speedo in the car (again take a look at some pics of my car to see how you could mount it)
#1167
Just received my GM120.. and now there is a new version to come..
I will be running my GM120 (i believe it has 7.2 software) with 9.5T (CS Motor.. looking for GM motor also).
#1169
Hi Martin,
How about 9,5T? No new motors?
#1170
Not sure
I have to check
I have to check
