Old 07-01-2008, 11:51 AM   #316
JevUK's Avatar
Originally Posted by Holmenkollen View Post
The bearings are fine. Iīm puzzled by this because I havenīt had any runtime issues before wtih GM stuff and are not having it with a Nosram speedo and motor. But thanks for all the help!
Fly me to sweden and I'll dyno test it for you
MRT, Novak, Spektrum, Sanwa, Tamiya, Alleven RC, Maxamps, CheapBatteryPacks, Duratrax Ice, Pro Peak PSU, Nuova Faor, McLarney Racing, Futaba, KO Propo, Team Associated, Enerland.
JevUK is offline   Reply With Quote
Old 07-04-2008, 05:13 AM   #317
Holmenkollen's Avatar
Originally Posted by Martin Hofer View Post
did you gear the motor longer in combination with the gm speedo in comparison to the nosram speedo? as the gearing has to be different quite a bit.
if you do not dump with the nosram esc than you cannot dump with a propper geared gm.
Iīd changed the gearing quite a bit with the Nosram motor but only resulted in that I dumped to a lesser extent but still dump. Far less power than with the GM motor though. I will do more testing with the GM gear and see if I can find a good gear ratio that both provides power and runtime.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 07-04-2008, 05:48 AM   #318
Kajman's Avatar
my friend has another problem, his dr speed 5.5t #97255 after 2 minutes of driving gets hot and finally stops. Even on GM esc engine doesn't go flawless, it stops sometimes. Any idea what can it be?
Other question is if I can get anywhere power which GM esc can handle continuosly, current is ok, but I don't thing it doesn't matter what is voltage I have Genius 40, 85 and 95. Do you have such a data?
Kajman is offline   Reply With Quote
Old 07-04-2008, 11:03 AM   #319
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
what gearing do you use with the dr speed motor?
I'd say you killed the magnet due to overgearing which makes the motor get hotter every time
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 07-04-2008, 11:10 AM   #320
Kajman's Avatar
That is my friends engine, he has gear ratio 8:0,so it doesn't seem scary. Motor had max 70 degrees C measured, esc is Hacker Master Car Sport, timing 30, amp limit 45. On Genius 40 with amp limit 42 it is not drivable at all.
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Old 07-04-2008, 11:23 AM   #321
A 5,5T is not meant to be used with a genius 40 anyway!
8.0 seems quite long
try to lower the gearing
and check motor and car for broken bearings or any parts keeping the car from beeing smooth
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 07-04-2008, 11:33 AM   #322
Kajman's Avatar
We found something inside the engine, piece of some cable, maybe sucked from surface. But magnets little worn, but do work, I don't know about winding
Genius 40 makes his job great with 4.5T even with current limit set to 42 amps and gear ratio 10.5 driving on LiIon and A123 Belivie me, small but great controller fighting hard to survive since my Genius 80 lost Fets, 85 has been still for over one month on his way from Graupner and 95 with new software is coming tommorrow
On this little G40 I drove 4s1p with over 500W engine for a while and he did it Everyday driving with current limit is no problem at all, even when outside is 25 deg. C. Really great controller with size of cell battery!
Anyway any idea about Genius powers? I am wondering how moch current I can let them go bei 9.9 and 13.2V (3s on G95 and 4s a123 on G85)?
Old 07-04-2008, 11:53 AM   #323
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
always liked GM, i slowly whittle away at bob stormer's leftover stock of sx3's for my m18 sedan racers. hope this stuff works as well too.
R
UltegraSTI is offline   Reply With Quote
Old 07-05-2008, 11:24 AM   #324
steveonamission's Avatar
Any chance of a price and release date for the GM 120
Always liked GM, use there mod motors, great power, only reason i havnt jumped on the speedo wagon, is the price...Ģ200+ here in the UK
And regarding the programming of it, what happens if you dont like the feel, and want to change something at the track? Can you still do that.
steveonamission is offline   Reply With Quote
Old 07-06-2008, 11:17 AM   #325
The first batch of ESCs will be available in a few weeks,
Some pictures have been uploaded to my blog, and can bee seen on redrc in the ets final gallery
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 07-07-2008, 02:12 PM   #326
Born2Run's Avatar
Martin
Is it normal to get less runtime in a 7T delta by changing the rotor from 13mm to 12.5mm with the same gearing and timing?
Whatever
Born2Run is offline   Reply With Quote
Old 07-07-2008, 02:24 PM   #327
Yes of course as a smaller rotor requires a shorter gearing
if you do not change the gearing accordingly you will get less runtime
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 07-08-2008, 01:00 AM   #328
Born2Run's Avatar
Tnx martin
I'll try with a lower gearing this time.By the way,the GM 7T delta with a 12.5mm magnet is awesome and if i can find the proper gearing it will be "the perfect motor".
Whatever
Old 07-08-2008, 11:28 AM   #329
JevUK's Avatar
Gregor my German bike parts supplier is getting a GM pro motor in for me. So anyone in the uk that wants one ask him he is very good. http://www.rc-motorradshop.de/
Old 07-08-2008, 04:48 PM   #330
Microtech racing sell the GM pro motors, or should i say GM pro motor, seeing as they only do the 6T delta, dont see any reason they couldnt bring in the 7T and 8T aswell
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
