Like Tree2Likes
GM Brushless
Old 10-04-2012, 01:00 PM
  #2896
*SBH*'s Avatar
New substitute part number is for the Genius 120 #97168 or 97168B with booster.
I find that very strange since the 75 is a lot smaller and cheaper...
*SBH* is offline
Old 10-05-2012, 12:25 AM
  #2897
Hi,
Can you only change modes on the ESC via the transmitter... as when i try it via the usb/computer,it asks if i want to copy to another mode?....
also the frequecy settings,do they make much difference?...as it says the lower you go the smoother the power....
sunktothenutz is offline
Old 10-05-2012, 12:38 AM
  #2898
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by sunktothenutz
Hi,
Yah it asks if you want to copy the settings from the mode you're on to the new mode you're going to, so to save the settings of one profile. They make a difference I found only if you go from one end to the other, but if you're making small increments it doesn't do a whole lot.
defcone is offline
Old 10-05-2012, 12:57 AM
  #2899
Hi,
Thanks...so its worth playing around with the frequency settings to get really smooth linear power...........
Old 10-05-2012, 01:03 AM
  #2900
defcone's Avatar
Hi,
I recollect not being able to get a smooth linear power with this esc following Martin's setup guide.
defcone is offline
Old 10-05-2012, 08:45 AM
  #2901
What is the difference between 97350 and 97305 ?
Manson is offline
Old 10-05-2012, 11:09 AM
  #2902
I think 97305 has a "modified" spec rotor, i.e a 5mm core rather than 7.25 as spec class rotors should be. Certainly there was one part number that had this rotor, and hence wasn't ever legal in the UK. Checking our list, 305 isn't on that list, and that would be the only reason.
97410 is the latest GM 10.5, and very good!
MattW is offline
Old 10-05-2012, 12:27 PM
  #2903
is it 97350 legal in UK ?
Manson is offline
Old 10-05-2012, 03:05 PM
  #2904
Yup, sure is.
MattW is offline
Old 10-06-2012, 09:19 AM
  #2905
Nico''s Avatar
I'm not sure, have a look on this page, rotor is stock rotor Efra legal.
http://www.graupner.de/en/products/9...5/product.aspx
Nico' is offline
Old 10-06-2012, 11:18 AM
  #2906
Fairly sure that's wrong. GM hasn't ever had a 12,5mm rotor that fits that series of motors that has the correct 7.25mm core. They have only ever had 12.3 and 12.4 rotors with 7.25 cores.
MattW is offline
Old 10-06-2012, 09:46 PM
  #2907
Nico''s Avatar
OK I understand, thanx for the explanation.
Nico' is offline
Old 10-17-2012, 02:27 AM
  #2908
Originally Posted by Martin Hofer
to be honest the turbo function is not meant to be played with really.
We found 1A/4ms is the best value. anything more messes up the throttle response resulting in unconsistant laptimes
So whats the point of turbo then???
Old 10-17-2012, 04:31 AM
  #2909
Hi Guys!
Was not racing for two years and decided to revive a bit of the past for this winter season.
I have GM Genius 120 controller with v7.2 firmware and GM Pro Motor 17.5T
Do you have any idea where I can get As-Soft for my Firmware?
Is there any possibility to upgrade firmware version in my speedo?
T tried to use current programming tool v 1.6.5 but it seems that I can't change a lot of functions with it.
Thnks for reply in advance.
Tilky is offline
Old 10-18-2012, 12:42 AM
  #2910
it's not Turbo in the sense of Tekin/Hobbywing turbo, it works differently !
chris_dono is offline
