GM Brushless
#2881
Hello I had a race this weekend and had many problems with heating.
Running gm 75 with 13.1v and setup basic_13.1 Motor gm 13.5 2012 using timing
The track is out door and fast with a 90 meter straight. I started with 4.37 fdr and after 3 minutes the car start going slowly after the run temp was 116 dg into software change fdr to 4.66 and again 3 minuts going slowly the last final run fdr 5.0 same problem.
I use to run x12 13.5 and it was fast and no problems
Any help would be nice tanks.
#2882
Hi,
This has probably been covered amongst the thousands of post on here, but can anybody please confirm to me that whether the gm software can be installed on a MacBook or not? Using the MacOS and not windows on mac...
Luke.
Luke.
#2884
Hi! I have CS rocket competition 120A esc which is rebranded GM Genius? I have huge problems to run Tekin SC4X 550 4,5t sensorless. What kind setup I need? Second question. Does esc handle new 4pole motors like hobbywing or tekin pro4?
#2885
hello,
Today was my frst drive with a gm pro 10.5 in 0 timing mode. One friend said me to had one more position of timing, i found a good gearing around 4.3 ( luxembourg track ).
Someone already tried on the max timing position ? whith a higher fdr like 4.8-5.0
thanks
thanks
#2886
you have to consider that the timing on the endbelll is a regulation that is strictly related to the track, so If you have long straights and few slow corner you can also try higher timing. However, especially in no timing, higher timing on the endball result in more rpms but less torque; less timing the opposite
#2887
Hi all I need a help,
I run in blinky mode with a x12 13.5 and gm120 upgraded to 13.1 software version. Ok now the problem is this:
I haven't few acceleration and too smooth brake
this is my set up:
freq 32
start amp 40
amp limit 90
soft start 67 ms
brake:
min 20
max 100
full 100
freq 1/4
Someone could help me?
thank you
this is my set up:
freq 32
start amp 40
amp limit 90
soft start 67 ms
brake:
min 20
max 100
full 100
freq 1/4
thank you
#2888
5 more questions:
Wich rotor on motor?
How much brake on the radio?
Softbrake?
Effect new brake software?
current limit for brake off?
Softbrake?
#2889
this is my set up:
freq 32
start amp 40
amp limit 90
soft start 67 ms
brake:
min 20
max 100
full 100
freq 1/4
thank you
this is my set up:
freq 32
start amp 40
amp limit 90
soft start 67 ms
brake:
min 20
max 100
full 100
freq 1/4
thank you
#2890
if you means epa 100%
new brake software and current limit disable
@daleburr
but mode 2 is timing mode, isn't it?
Thanks everyone for help?
#2891
@daleburr
#2892
Assuming you have done a properly setup on the radio you should have more than enough brakes, but try to tick the current limiter off.
#2893
#2894
info
hi i was looking for a gm 75 with booster but it seems to have disapered from most site
the only one i'm finding is the gm 80r race 2 with booster
anybody can let me know how they compare or where can i find the 75 with booster
thanks
thanks
#2895
According to the Groupner / GM site, the 75 (both versions) has been discontinued.
