GM Brushless
#2582
your temp cutoffs are quite high as well, start over from mode 9 and work up from there using martin's guide
#2584
start amp and amp limit are set 80-120 depending on how i want it to feel
#2586
[AddData]
Brushless=1
Sensor=0
Car=
Place=
BarCode=
Comment=
Motor=
Pinion=0
MainGear=0
InternalGearRatio=0
TireDiameter=0
MaxRotationSpeed=27
MaxCurrent=145
[GeniusData]
StartAmp=80
AmpLimit=120
Turbo=1
BrakeMin=20
BrakeMax=100
AutoBrake=0
FullBrake=100
ABS=0
RPMLimit=13
Polzahl=2
Frequency=9
Reserved=16
MaxReverse=30
Softgas=50
PowerCurve=0
Autogas=0
Switch=6
OnAfterUSB=1
Timing=0
TimingWith=2
[GeniusDataAdv]
Reserved1=141
Softbrake=100
FullThrottle=22545
NeutralPoint=15638
FullBrakePoint=11140
NeutralPointWidth=80
ControllerMode=2
VoltageCutOff=250
PWMStartNoSensor=128
LimStartNoSensor=30
EffectNewBrake=150
Reserved2=9
SwitchPointRPM=125
MaxTiming=21
FixTiming=5140
Timing2=110
Timing1=90
CutOffTempContr=125
MaxRPM=27
Firmware=116
MaxCurrent=145
CutOffTempMotor=115
MaxESCTemp=76
MaxMotorTemp=0
ActESCTemp=19
so some thing like this
Brushless=1
Sensor=0
Car=
Place=
BarCode=
Comment=
Motor=
Pinion=0
MainGear=0
InternalGearRatio=0
TireDiameter=0
MaxRotationSpeed=27
MaxCurrent=145
[GeniusData]
StartAmp=80
AmpLimit=120
Turbo=1
BrakeMin=20
BrakeMax=100
AutoBrake=0
FullBrake=100
ABS=0
RPMLimit=13
Polzahl=2
Frequency=9
Reserved=16
MaxReverse=30
Softgas=50
PowerCurve=0
Autogas=0
Switch=6
OnAfterUSB=1
Timing=0
TimingWith=2
[GeniusDataAdv]
Reserved1=141
Softbrake=100
FullThrottle=22545
NeutralPoint=15638
ControllerMode=2
VoltageCutOff=250
LimStartNoSensor=30
EffectNewBrake=150
Reserved2=9
SwitchPointRPM=125
MaxTiming=21
FixTiming=5140
Timing2=110
Timing1=90
CutOffTempContr=125
MaxRPM=27
Firmware=116
MaxCurrent=145
CutOffTempMotor=115
MaxESCTemp=76
MaxMotorTemp=0
ActESCTemp=19
#2587
[AddData]
Brushless=1
Sensor=0
Car=
Place=
BarCode=
Comment=
Motor=
Pinion=0
MainGear=0
InternalGearRatio=0
TireDiameter=0
MaxRotationSpeed=27
MaxCurrent=145
[GeniusData]
StartAmp=80
AmpLimit=120
Turbo=1
BrakeMin=20
BrakeMax=100
AutoBrake=0
FullBrake=100
ABS=0
RPMLimit=13
Polzahl=2
Frequency=9
Reserved=16
MaxReverse=30
Softgas=50
PowerCurve=0
Autogas=0
Switch=6
OnAfterUSB=1
Timing=0
TimingWith=2
[GeniusDataAdv]
Reserved1=141
Softbrake=100
FullThrottle=22545
NeutralPoint=15638
ControllerMode=2
VoltageCutOff=250
LimStartNoSensor=30
EffectNewBrake=150
Reserved2=9
SwitchPointRPM=125
MaxTiming=21
FixTiming=5140
Timing2=110
Timing1=90
CutOffTempContr=125
MaxRPM=27
Firmware=116
MaxCurrent=145
CutOffTempMotor=115
MaxESCTemp=76
MaxMotorTemp=0
ActESCTemp=19
Brushless=1
Sensor=0
Car=
Place=
BarCode=
Comment=
Motor=
Pinion=0
MainGear=0
InternalGearRatio=0
TireDiameter=0
MaxRotationSpeed=27
MaxCurrent=145
[GeniusData]
StartAmp=80
AmpLimit=120
Turbo=1
BrakeMin=20
BrakeMax=100
AutoBrake=0
FullBrake=100
ABS=0
RPMLimit=13
Polzahl=2
Frequency=9
Reserved=16
MaxReverse=30
Softgas=50
PowerCurve=0
Autogas=0
Switch=6
OnAfterUSB=1
Timing=0
TimingWith=2
[GeniusDataAdv]
Reserved1=141
Softbrake=100
FullThrottle=22545
NeutralPoint=15638
ControllerMode=2
VoltageCutOff=250
LimStartNoSensor=30
EffectNewBrake=150
Reserved2=9
SwitchPointRPM=125
MaxTiming=21
FixTiming=5140
Timing2=110
Timing1=90
CutOffTempContr=125
MaxRPM=27
Firmware=116
MaxCurrent=145
CutOffTempMotor=115
MaxESCTemp=76
MaxMotorTemp=0
ActESCTemp=19
#2590
i have sent my gm120 to update,
after they received the speedo they informed me that they require 8 weeks to make the update.
this is unbelievable , so i miss the season.
all guys beware of sending the speedo for update.
#2591
If i were in your pants i would have asked before send it in.
#2592
i asked, they didn't inform me about the timing....
it's weird that a simple update requires so much time.
#2593
Did anyone ever played with Turbo?
#2595
hold the brakes on slightly and turn the motor. Tthe lights on the speedo will change to show you the sensors
