BMI's DB12R
Old 07-01-2009, 08:46 AM
  #7516
Originally Posted by Fabricio
Where to get kit on the internet?I have searched on some webstores but could not find it.
bmiracing.com
SRW141 is offline
Old 07-02-2009, 12:44 PM
  #7517
Here's my latest new paint for my DB12RR Should look even better once it is fully cut out with a couple stickers on it. I didn't get as much color contrast as I had hoped on the flames so next time I will probably use different colors.
InspGadgt is offline
Old 07-02-2009, 03:37 PM
  #7518
chris moore's Avatar
Trader Rating: 96 (99%+)
Nice design, looks good Inspector
chris moore is offline
Old 07-03-2009, 03:04 AM
  #7519
Ok got it all cut out and stickered up now
Old 07-03-2009, 09:22 AM
  #7520
AOD
AOD's Avatar
Car looks good Burt, I look forward to baptizing it tomorrow!
AOD is offline
Old 07-03-2009, 10:58 PM
  #7521
3rd-dan's Avatar
Good paint job gadgt.
3rd-dan is offline
Old 07-04-2009, 02:45 AM
  #7522
And the BMI siblings
Old 07-04-2009, 07:28 AM
  #7523
CarlosG.'s Avatar
InspGadgt, ygpm.
CarlosG. is offline
Old 07-04-2009, 08:58 AM
  #7524
PartTime's Avatar
Hey guys. Can some of you post pics of your flat servo install? Im having a hard time getting the link flat when looking down on the car. Either the servo is pushed up against the front arm or I had to drill new holes to get the servo back enough. Its not the new RR if that helps.
Next question. The new RR L-plates, is the extra hole more forward making the plate longer or is it the same length with an extra hole to make it stiffer?
Got my new 12R running yesterday. Spent most of my time getting the chassis sorted out. Started out with a little push on/off power. Played with a few things and ended up with a slot car. The car is very honest. Every change shows on the track. Very nice compared to some of the cars I have driven lately. Most of my problems is with the Akerman. -15% expo was too uneven for me and -10% wasn't enough. Just to overly responsive for me. I drilled new holes to move the servo back for the next time out but kinda worrying that it might take too much on power steering out. I allready have the upper arm forward.
Im sure a few will ask for the setup, its kinda odd and not done yet but this is what I ended up with.
Front
5deg block
arm forward (2degs ?)
.020 spring
7000 on kingpin
.05mm droop
1 deg camber
0 toe
Rear
Thick L-plate with/out set screw
7000 in tubes (thinking 10000 would be better)
30wt and red spring (blue was too soft and red too hard, have gold now and going 35wt next time out)
2mm pod droop (have 1mm now)
Black ballstud with no washers on mount
Tires
Magenta frt with 3/4 inside doop
Pink rear full doop
The fronts are still getting a little build up and wearing faster than the rear. The only other thing I can think of is that if the car gets a little off line it wont come back. Thinking maybe .018 front and thin plate in back will cure that. This way I dont have to goto softer tires.
PartTime is offline
Old 07-04-2009, 09:35 AM
  #7525
C5Vette's Avatar
Jason,
What is the part number for the standard flex plates? Also, do you have them in stock? I can't find them on your website.
Thanks,
Ray
C5Vette is offline
Old 07-04-2009, 11:19 AM
  #7526
Ran single cell lipo for the first time. Only thing I changed was front/center shock springs Went to 18's and a 10lb from 20's and 12lb. Car drove great in 4 cell 17.5 and 13.5.
Didn't expect that much of a change but WOW! Car had no steering whatsoever. Full wheel turn and it pushed to the boards. I'll have to start over on the setup. I ran my normal BSR XX pinks front and rear. Good place to start would be there. Kind of scary, but I'm thinking I need to go softer in front? I'll also move the battery all the way back to try and get better weight transfer for more steering on corner entry. Anyone else been in a similar situation I'd appreciate any more tips/idea's. Thanks!
LAGuy is offline
Old 07-04-2009, 11:40 AM
  #7527
Not sure how much these will help as I'm using the CRC frontend but here you go.
Are you using the silva shock or the original IRS shock? On the silva I went to a 6lb spring and blue on the IRS using lilac or XXpink fronts. Sauceing only inner1/3 but our carpet track is high bite black ozite.
Old 07-04-2009, 01:22 PM
  #7528
GLITTER LIDZ's Avatar
I liked your Birds car....but damn! they is sweet!!!!!!!
GLITTER LIDZ is offline
Old 07-04-2009, 04:09 PM
  #7529
PartTime's Avatar
Ya, mine pushed a little right off the bat. Red spring really woke it up. But should have put 35 or 40 in the shock to tame the transfer down some. Way to fast with 30. Also the 7k in the tubes helped with the double steer. I bet 10k would get rid of the last little bit. This is the old car so your oil would be diffrent. By the end of the night I was doping 3/4 front tire.
One thing I have done with the lipo cars is mount EVERYTHING as far back as i can. Smallest spur to get the motor back. Pack in back, speedo and rx right against the pack. Servo behind the tie rods. Then take caster out till it drives upto the corner with out lifting. When you lift it snaps around the corner and your gone !
Chris Moore.....Thanks for the pics. My tie rods had that much angle when looking from the top and it was way too responsive for me right around center. At the ends it was great. I have drilled new holes to move the servo back and now my tie rods are straight when looking from any angle. Should be able to get a test run in the next couple of days to see if it smoothed things out.
DK
PartTime is offline
Old 07-05-2009, 01:38 AM
  #7530
Thanks man...took a long time to get what I was seeing in my head to come out close on the cars...but it was worth it
