BMI's DB12R
Old 02-05-2009, 09:19 AM
  #6961
Originally Posted by Jeremy Otis
A quick fix to eliminate slop in the ball cups is to take a little bit of fuz off of the end of a Q-tip and stick it in the cup. Just a little. Now snap it on and you will have bind free and no slop. Now you can use whatever ball cup you want.
Jeremy
Yup I use that one...but the Losi rod ends don't have a cup...they are more of a ring like a captured rod end.
InspGadgt is offline
Old 02-05-2009, 09:27 AM
  #6962
protc3's Avatar
Originally Posted by PartTime
Jason, i just placed an order last night threw you. Do I get the free shipping too?
DK
We didnt get it set up until this morning so probably not.
protc3 is offline
Old 02-05-2009, 09:31 AM
  #6963
PartTime's Avatar
Story of my life. Day late and dallor short.
Barry...you thinking about a 1/12th?
Jeremy...you have PM
DK
PartTime is offline
Old 02-05-2009, 09:59 AM
  #6964
protc3's Avatar
Sorry about that buddy
protc3 is offline
Old 02-06-2009, 08:05 PM
  #6965
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
Just kinda came out of my Snowbirds induced coma(I'm sure you have seen the pictures). Anyways for the first time out with the car ever I almost made the show. I would of if I wouldn't of had HP issues all weekend in 12th scale. My car was good and I drove it pretty good but just needed a little more rip, probably was a combo of gearing and a speedo/timing choice kinda thing.
Wanted to thank Jason for giving me the opportunity to run the car and I'm sure I will do better next time I learned a lot about 12th scale last weekend, including the car.
I'm ready to try again at the nats for sure. Can't wait actually.
L.Fairtrace is offline
Old 02-06-2009, 08:58 PM
  #6966
Sorry,
I guess I should have read back a little further.
Jeremy Otis is offline
Old 02-06-2009, 09:30 PM
  #6967
No problem dude
Old 02-06-2009, 10:11 PM
  #6968
Impulse_racer's Avatar
Here's my DB12RR. Thanks Jason for all your help and tips.
Impulse_racer is offline
Old 02-06-2009, 10:21 PM
  #6969
Looks nice there Impulse...love the paint scheme. How you liking that Redline? I'm thinking about getting a 13.5 one.
Old 02-06-2009, 11:06 PM
  #6970
Thanks. I am lovin' my RS Pro/Redline 10.5 combo. It was so good straight out of the box that I almost didn't bother with the Hotwire. When I did get the Hotwire I had to pull out the barbeque sauce because I cooked the rotor real good. I am on a smallish track and had to drop a lot more teeth than recommended after adding the 189 update. But Tekin was great about getting me a new rotor before the next weekend and at practice it was FAST. REAL FAST.
Old 02-06-2009, 11:18 PM
  #6971
Yeah I had to drop 5 teeth when I went to 189 at the Birds and considered dropping 1 more just to get a bit more zip out of the corners.
Old 02-07-2009, 05:44 PM
  #6972
avs
avs's Avatar
Default steering setup question
hello all.
i am just putting together db12rr and everything went together except for rigging the steering.
(by the way, thank you Adrian for your diff setup treatise, i would have been wasting $$ on carbide balls and never thought to burnish the rings which really helps smooth the action)
anyways, i have tried to use the angled mount to get started and have had troubles with the arms fouling on the inside wheel side's upper hinge pin, or rather the head of the upper hinge pin (the retainer circlip is on fwd end of the hinge)
i tried lowering and raising the servo, and moving fwd with the balls behind the horn but nothing lets the arms have a completely free range of motion. is this necessary? my eyeball can't tell how much steering throw is enough just looking at it.
thanks in advance for any insight or guidance.
avs is offline
Old 02-07-2009, 06:05 PM
  #6973
protc3's Avatar
You do not need that much steering throw. You will be fine setting it up the way you have it. Take a pic and post it for me when you can so i can see and make sure i am understanding exactly what you are saying.
protc3 is offline
Old 02-07-2009, 06:17 PM
  #6974
Nova F1 Racer's Avatar
Hey Jason, please send a Schreff a rear pod set and have Keira bill me... That was a life saver at the birds....
Nova F1 Racer is offline
Old 02-07-2009, 07:11 PM
  #6975
protc3's Avatar
Dont worry about it buddy. I took care of it already.
protc3 is offline
