BMI's DB12R
#6421
Imagine that your TC had a big ball joint in the middle of the chassis, so the front and rear axles could move relative to each other - that's a 12th car!! It's not often that we use the tuning tweeks from a TC to tune a 12th car. HTH
#6422
Hi Jason,
Can I get DB1020R 2.5mm C/F Lower Pod Plate for the DB12RR?
I couldn't find this on the website.
If I order it in my next order then you include it?
#6425
Thank you.
#6429
darn, I was born in the "wrong" country That's i, I'm going to states!
P.S.: do they have Christmas offers for greencards?
#6430
The card is allready green how much more christmasy does it need to be
#6431
Originally Posted by SlowerOne
Not many things used to tune a 12th car come from TC. The difference is that in a 12th car you have a chassis with a joint in the middle!! Things like roll centres do come across, but after that it doesn't help that much to have tuned a TC.
understand there are big differences, which is why I was asking what effect shiming the ball joint has. If it's an RC change it should lower the RC by making the top link - I guess that's the shock in this case - flatter in relation to the bottom, correct
#6432
Draw an imaginary line through the center pivot ball on through the upper ball stud that the shock mounts to. Think of that imaginary line like the suspension arm on your TC and that will give you the relative shock angle on the suspension.
#6434
#6435
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
I have the new shock on my 12RR, no trimming necessary on the ball cups. I actually use the 2nd and 3rd holes from the rear of the chassis to locate the shock mount, and had to turn the ball cups on the shock 2 turns out from bottom to lengthen it.
