BMI's DB12R
#5329
thanks
THANKS GUBBS! ANY SETUP HELP IS A MAJOR PLUS SINCE THERE IS ONLY 3 OF US RUNNING THIS CAR HERE IN NORTHERN MINNESOTA. I AM REAL IMPRESSED ON HOW IT IS GOING TOGETHER. JUST A LITTLE SANDING ON THE FRONT END TO GET THINGS LOOSE BUT EVERYTHING ELSE SEEMS TO FIT PERFECTLY.
#5330
Trader Rating: 51 (100%+)
Yo Jason Happy Birthday man
#5333
Hey man, I don't know about you guys, but I learned the art of building a front end from some of the best, Donny Lia and Mike Haynes(A-Mainers at Vegas right now), and they always told me the front end isn't supposed to be loose. The knuckles are supposed to be tight on the kingpin and they don't need to drop down. The only cutting, milling, ETC you should do is on the upper ball stud, and that should be to cut it a little so your 3 shims will fit in. I ran my car, with my front end with the knuckles reamed so they drop, and then again with the front end built right, and I was .2 faster per lap wit the front end built right. The car felt much more precise and alot less lazy and it reacted better. It also didn't have that odd tendency to want to keep turning out of a corner like it used to.
#5334
#5336
I've ran both ways and couldn't tell a difference in my laps. I did notice when I didn't ream the knuckle I did have the king pin get stuck causing more preload on the spring on one side then the other. Also you'll need to sand either the upper arm or the caster block so the upper arm moves freely. If you don't the upper arm binds horribly, especially with the IRS caster shims which are slightly thicker then the stock AE ones.
#5337
happy birthday jason
#5338
It's You're Birthday?
Jason,
Happy Birthday from Del City, Oklahoma!
#5339
Man, all these years I should have been building with a bind...
