BMI's DB12R
Old 02-12-2008, 10:35 AM
  #4111
Nova F1 Racer's Avatar
Originally Posted by Mason
I think I hit that one once or twice..
Yep... 1 qualifier I got punted 3 times completely OUT of track!!! And the car never even tweak a little!!!
Nova F1 Racer is offline
Old 02-12-2008, 10:37 AM
  #4112
wallstreet's Avatar
Trader Rating: 24 (93%+)
Hey guys just wanted to let you guys know i have a pretty new bmi db12r that i am looking to get rid of cause my wife just had our first child and i just cant run everything i have right now... or even get to the track that much.
Car only has about 6 or so packs through it and in nice condition. click on my name and look for the thread if intrested .
Jason thanks again for making a great 12th scale .
wallstreet is offline
Old 02-12-2008, 11:07 AM
  #4113
protc3's Avatar
Congrats on the new addition buddy.
protc3 is offline
Old 02-12-2008, 05:28 PM
  #4114
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
I've had some issues w/ tweak and/or weight balance on my DB12Rs (one configured for brushless, the other brushed). I've used IRS balance buttons on a level surface to the best of my ability to attempt to balance both cars. I have a little stack of lead weight on the right side of my cars behind the servo and in front of the receiver.
This past weekend I finally broke down and decided to tweak the car as they were both giving me fits on right handers (at least they were consistenly problematic). After tweaking my car I went from turning 11.1s laps to 10.8s laps and was able to start attacking the track (note -- that caused other problems -- but that is another story).
Am I doing something wrong? Should I try other balance buttons? Is there a recommended method for using balance buttons than just pushing the car over to both sizes (doesn't seem that precise but other DB12R runners are doing this). Do I need scales?
When I discovered my car had a tweak (and after doing so, we found other DB12Rs with a tweak on Sunday) I loosed everything on my pod, hockey sticks and front end and then re-tightended. The car had the same +1 tweak on a Integy Laser Tweak Board (I did the coin on the front wheel test too just to verify).
hanulec is offline
Old 02-12-2008, 05:48 PM
  #4115
protc3's Avatar
I would check out your front end. It can be a collapsed spring,bent kingpin or even a front arm tweaked. It is not possible for the rear to be tweaked with the way it is constructed unless it is broken. If you like you can give me a call tommorow and i can run you through the things to check
protc3 is offline
Old 02-12-2008, 05:54 PM
  #4116
I don't have a DB12R (yet) but follow them closely and am using the same front end setup. I found with the stock IRS front arm spacers I had some tweak in the front arms. They just would not sit level for me. I picked up a set of the BMI front arm spacers and now they are perfect. Also as Jason mentions check your front springs...I did find that over time one spring was more compressed then the other and had to compensate with shims or replacing both springs.
InspGadgt is offline
Old 02-12-2008, 05:56 PM
  #4117
protc3's Avatar
Keep in mind that the car will need to be balanced for it to read right on a tweak board. This really is the only way to make any 1/12th car run to its best potential. Choose electronics placement wisely. You really dont want to have to tweak the car with tweak screws on any car. It really is only a preload adjustment. Running one spring with more preload than the other is just going to be covering for a problem elsewhere and it will show in how the car drives.
Also remember that the front wheels need to be dead straight when checking tweak and your camber angles need to be identicle from left to right or you will see variations.
protc3 is offline
Old 02-12-2008, 05:57 PM
  #4118
protc3's Avatar
Im glad you like the spacers buddy
protc3 is offline
Old 02-12-2008, 05:59 PM
  #4119
very much so
Old 02-12-2008, 08:54 PM
  #4120
EricF's Avatar
Jason,
do you have any plans on carrying other parts from IRS (sure lube) or Slapmaster (thrust bearing)?
also, when do we get to see the grub screw droop setting thing, will it required a lot of new parts or can we fit our selves?
E
EricF is offline
Old 02-12-2008, 09:39 PM
  #4121
Mason's Avatar
i have a feeling it will mount in current holes.
Mason is offline
Old 02-13-2008, 02:41 PM
  #4122
protc3's Avatar
Originally Posted by EricF
Jason,
E
I will be carrying more products as time goes on. surelube is my next one. I really like the stuff and its easy to reference.
I started on the prototype droop adjuster today and should have it complete tommorow. I will take some pics.
protc3 is offline
Old 02-13-2008, 02:43 PM
  #4123
protc3's Avatar
Mason is correct. It will fit right on the center pivot. The only part i needed to change was the 1 pc sidewing cross brace. I added a set screw hole in it. I hate to make changes like this but it was necesary.
protc3 is offline
Old 02-13-2008, 07:58 PM
  #4124
EricF's Avatar
Cool... I guess I'll have to wait. Thanks. E
EricF is offline
Old 02-15-2008, 04:08 PM
  #4125
protc3's Avatar
Hey guys,
I wanted to give you a quick update. I made the new pod droop adjuster and i had a few little problems that i need to work out. I will get it figured out and post pics as soon as possible.
protc3 is offline
