LRP 13.5, anyone have a go yet? >
Old 12-31-2007, 01:00 PM
  #166
Registered User
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Can anyone help me as to how to get one of these apart. I pulled the 3 screws off, took the plastic cap off and can't seem to get the thing apart. I didn't want to pull up on the circuit board for fear of ruining it. Any tips. I just got a sintered and want to do the switch.
Dasupacat1 is offline
Old 12-31-2007, 01:14 PM
  #167
trilerian's Avatar
Trader Rating: 51 (100%+)
If it is like the Novak 13.5, you pull off the top end bell take the bonded rotor out and put the sintered in. It sounds like you are trying to take off the back of the motor.
trilerian is offline
Old 12-31-2007, 01:38 PM
  #168
Verndog's Avatar
Trader Rating: 16 (100%+)
As posted you have the wrong end off. You dont need to even loosen that end, just the shaft end 3 long screws, pull the end bell, then the rotor comes straight out. Also, its a good idea to use a fine tip felt pen to mark endbell to can to align it back correctly putting back together. Do not evertighten the screws putting back together, I've seen one that was stripped out, just 3 fingers to tighten will hold it.
Verndog is offline
Old 01-15-2008, 06:51 PM
  #169
nashrcracer's Avatar
does anybody know wether the newer ones are coming out with sintered rotors now. don't want to buy one from tower and get it bonded. I hope they have kept up with novak in that regards.
nashrcracer is offline
Old 01-16-2008, 12:16 AM
  #170
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 101 (100%+)
How do the LRP's stand up to the Novaks? Novaks are the only ones allowed around here. So with the news with ROAR allowing brushless motors now in stock and 19turn, I want to the the LRP Sphere Comp 07 or the TC edition and would like to keep the blueness in motors lol
BSchorr is offline
Old 01-16-2008, 01:06 AM
  #171
Sigearhead's Avatar
Trader Rating: 74 (100%+)
All the new motors should now all be sintered. With the new 14mm sintered rotor these motors are ballistic. Very fast and very torquey. Definitely faster than the Novak regardless of the rotor on the Novak. This is the 13.5. Not sure about the other winds.
Sigearhead is offline
Old 01-16-2008, 01:11 AM
  #172
GreaseMonkey's Avatar
I'd be wary of buying an LRp 13.5 right now as apparently the ROAR rules are going to be a max rotor of 12.51mm and min of 12.39mm. With the LRP being 14mm it won't be roar legal.
GreaseMonkey is offline
Old 01-16-2008, 01:15 AM
  #173
BSchorr's Avatar
Guess we will see what happens there.
Wonder when LRP will make a 17.5 then.
BSchorr is offline
Old 01-16-2008, 05:45 AM
  #174
I bought an LRP 13.5 from Tower two weeks ago and it came with a sintered rotor.
Squating Goat is offline
Old 01-16-2008, 11:32 AM
  #175
Sigearhead's Avatar
As long as your track or club allows it I wouldn't worry about ROAR rules. ROAR rules are set for National level races not necessarily need to be followed by your track or club.
Old 01-16-2008, 11:43 AM
  #176
Verndog's Avatar
Exactly! I got myself pretty worked up over it till I taked to our track owner. He said far too many people are already running 13.5, and there is a series within several tracks that is running also that will all continue reguardless of what ROAR decides. Many tracks, I have a feeling, will not follow suit with ROAR. We run 13.5 and stock together (when one of the few stocks shows) and they are not alot different as far as top speeds, torque out of the corners the 13.5 has the advantage.
Verndog is offline
Old 01-16-2008, 11:44 AM
  #177
Rick Hohwart's Avatar
February.
LRP's all-new X-11 "stock" spec motors will be avaialble in 10.5, 13.5, 17.5, and 21.5 configurations that meet ROAR "stock" BL motor specifications. This means a 12.3mm sintered armature, anodized external color coded (for each wind) parts, and an armature that is easily identifiable by tech crews.
There will also be 8.5 and 9.5 versions of the motors for use by clubs in limited modified class racing and are perfect for low grip off-road modified applications.
X-11 Stock Spec motors are scheduled for February delivery.
Additionally, 12.5 and 13.0 mm sintered rotors for X11 MOdified motors will be available at the same time.
Rick Hohwart is offline
Old 01-16-2008, 11:46 AM
  #178
Anthony.L's Avatar
Trader Rating: 41 (100%+)
Good to hear that Kevin.
Anthony.L is offline
Old 01-16-2008, 11:50 AM
  #179
Verndog's Avatar
Originally Posted by Rick Hohwart
February.
Really?? All that done by next month?? Sounds like you guys have been involved with an "inside scoop" on the new rules while there in the process of being made. thats good to see. I'll stick with my 14mm rotor for club racing though thank you.
Verndog is offline
Old 01-16-2008, 11:51 AM
  #180
But if they did, how great would R/C racing be!
