Team Orion Vortex Brushless motor
#151
#152
#153
I think the problem are the packs being 1 year old. My IB4200 nearly 18 month old are still working but they lost a lot of runtime.
#156
As the LRP 5.5T is using bonded rotor from factory and the Orion 5.5T is using sintered rotor they will have different RPM or KV. The Orion in compare will need higher gearing.
#157
#159
#161
Hi all,
As anybody managed to get the bearings out?
I tried to remove the bearings yesterday, without any sucess. Not only that, but i managed to get the motor the make a funny grinding noise, probably from damaging the bearings.
So, does anybody know how to remove and where to buy bearings for these motors?
Thanks in advance
Thanks in advance
#163
Hi all,
Thanks in advance
Thanks in advance
At the sensor side it's more difficult because you can damage the sensor if you are not very carefull.
I used the 3 short screws from the backside of the motor to built a place to let the bearing tool rest on whilst pulling the bearing.
Inserting is a little more difficult. I let the tool rest on the three sensors and used a lot of shims on the bearing site to push the bearing in place.
Did this already a few times without problems.
BTW: The funny noise can also come from a bent ventilator. It can hit the winds if a little displaced.
I dunno where to buy the bearings. Maybe you should contact Team Orion direct on their forum.
Good luck
#165
i'm think use slotless BL motor faster in these big track !
