Serpent to 1/10th EP Touring Kit S400 >
Old 01-28-2008, 07:48 AM
  #1141
spurgear's Avatar
Ran my car on saturday first time. Ran it in an outlaw race with other cars. I was dissappointed with the performance. I ran the stock setup with 37 shore 26mm foams all around. Car was the slowest from the start. Also with the front spool the car didnt want to turn. It was like rocking during the turns. The back would also give way when i tried to turn in the sharp turns.
spurgear is offline
Old 01-28-2008, 11:54 AM
  #1142
XACDesigns's Avatar
Trader Rating: 15 (100%+)
What was your gearing like? I know at the last race my car was pretty slow, I had to increase the pinion to a 51 tooth with the stock 102 tooth in 13.5 to be competitive.
XACDesigns is offline
Old 01-28-2008, 05:30 PM
  #1143
spurgear's Avatar
Im using the stock 102 64P spur with a 24 pinion
spurgear is offline
Old 01-28-2008, 07:34 PM
  #1144
TimPotter's Avatar
Spurgear, maybe post more of your setup so we can help you out... As Far as speed, that is all gearing and motor... so include that too...
For those that are looking for a Front Ball diff, I talked to Doug at SerpentUSA today, and he said they have some coming in.....
TimPotter is offline
Old 01-29-2008, 02:03 AM
  #1145
pardypooper's Avatar
Paul
Are you running kit setup ? One thing I never have had issue with is rear end grip, if anything there is to much.
Are you running rubber or foam as well ?
Yes running kit set up on rubber, ashfelt track generally good traction.
pardypooper is offline
Old 01-29-2008, 05:30 AM
  #1146
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
13.5 should look at a 88 spur, 40 - 44 tooth pinion.
Novak We ran 44-88 on the pinion spur for 13.5 on foam. rubber would be a bit lower do to the taller tire.
ammdrew is offline
Old 01-29-2008, 11:29 AM
  #1147
jo90's Avatar
Paul, I don't know what to tell you, I ran mine outdoors the very first time I had the car, totally kit setup on Corally SSB tyres (comparable to a CS27) and I had bags of rear end grip.
Sill questions - have you checked tweek etc ?
jo90 is offline
Old 01-29-2008, 11:36 AM
  #1148
spurgear's Avatar
Ok im using a mamba 7700kv with a 3200 lipo team orion lipo. Gearing is 102 teeth 64P with a 24 teeth pinion. The radio is a 3PK Futaba with HRS receiver. The ESC is also Mamba with all graphs setup linear. The tires are all 26mm 37 shore. Body is mazdaspeed 6 version. I will post pics today. Any more info required? Practice is this weekend. I have no idea what else to try. I tried fitting 30mm rear foams but it touches when it fits. Should i grind to fit it?
spurgear is offline
Old 01-29-2008, 05:00 PM
  #1149
KAHUNA's Avatar
Cool
Ok anybody have a site to order the rear toe in block , Serpent dont have either 0 or 1.5 in stock . Or will any other manufacture work and where can I get one !
Thx ....
KAHUNA is offline
Old 01-29-2008, 06:21 PM
  #1150
spurgear's Avatar
Here u go
spurgear is offline
Old 01-29-2008, 06:49 PM
  #1151
TimPotter's Avatar
Spur,
We generally do not run Foams on asphalt around here. And I am not familar withthe mamba system, so I cannot give you gearing/rollout for that. Was the motor hot? did it seem like it came up to speed real quick, then went flat ? When you setup the speedo, was the radio EPA set to 120% ?
I would first see if taking a little droop out of the rear to stop the low speed oversteer. Is the car balanced ? ,from the pictures I do not think it is...
if you lacking overall bite, there are a million things to do.. but try starting out with laying the shocks over....
Old 01-30-2008, 04:58 AM
  #1152
ammdrew's Avatar
Both are in stock. Cwits, or The Track can get them in pretty easy.
ammdrew is offline
Old 01-30-2008, 07:35 PM
  #1153
kschu's Avatar
Trader Rating: 16 (100%+)
hi guys, i jus finish a drift race using s400...this car handle very well. i manage to finish in 1st place....hehehe
kschu is offline
Old 01-30-2008, 11:27 PM
  #1154
UK.hardcore's Avatar
Hey all,
I'm thinking about the Serpent S400 to drift on indoor carpet tracks.
Car looks great and support here is great too. Belgium, right next too The Netherlands.
UK.hardcore is offline
Old 02-02-2008, 06:57 PM
  #1155
LOW ET's Avatar
Trader Rating: 109 (100%+)
where's the best place to get this kit in the usa? where can i get the following parts:
front one way #401110
foam conversion #401145
gear diff #401144
rear body brace #803180
LOW ET is offline
