Serpent to 1/10th EP Touring Kit S400 >
Old 01-20-2008, 06:17 PM
  #1096
stiltskin's Avatar
Trader Rating: 103 (100%+)
Originally Posted by DaveW
Guess whats sitting on MY pit table?!
RacerZ... you da MAN!!
i'm curious to see how you get the shaft to spin between those two diffs.
Racer Z, you may want to check your car for Associated parts when he gives it back.
stiltskin is offline
Old 01-20-2008, 07:04 PM
  #1097
TimPotter's Avatar
Trader Rating: 15 (100%+)
Just got back from the FSEARA State Race, had bunch more S400's in the field then the last race. All the cars seems to be working pretty good. The conditions were pretty difficult, track temps were up and down ,it went form 75 to 45 in temps.
We got to test with the gear diff, and it is very promising.
I know we had a car in the A in both Sportsman ( 13.5) and Expert ( 10.5).
We run our mod class, in a Reedy, heads up manner, and I had some real solid runs.
TimPotter is offline
Old 01-21-2008, 05:14 AM
  #1098
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
Another great weekend for the S400 at the New years Rumble race.
Running the fastest laps we sat just a tenth or two outside of TQ, and were set for a great A Main. But Parked the car on the first lap, working through the field pulled a turnbuckle. Car was excellent and turned the fastest laps. Worked on some different setups and changes, ran the thinner chassis to try and perfer how the thick carpet chassis feels in the car. Gear diffs still untouched since vegas and working great.
ammdrew is offline
Old 01-21-2008, 11:39 AM
  #1099
DaveW's Avatar
Oh im sure ill pimp it out with some AE washers and various other goodies... just like my XRay T2! I dunno tho, i really like the looks of this car... even the orange washers/spacers are p i m P!
DaveW is offline
Old 01-21-2008, 11:40 AM
  #1100
DaveW's Avatar
The gear diffs, are they run front and rear?
DaveW is offline
Old 01-21-2008, 12:17 PM
  #1101
spurgear's Avatar
Bought this as my first electric car and installed the 3200 orion lipo. Im dissappointed it didnt fit as i swore i read on this post that it will. I really did allot of grinding but still im not happy with the fit. I need it to sit more to the right as its too close to the main spurgear. Also the positive wire out of the battery is even closer to the rear belt pinion. Anyone else notice this?
spurgear is offline
Old 01-21-2008, 12:46 PM
  #1102
Trader Rating: 17 (100%+)
Yes, andrew is running the prototype diffs both front and rear.
Kave is offline
Old 01-21-2008, 01:34 PM
  #1103
XACDesigns's Avatar
I know it's not a 3200, but my 3600 fits really well. I had to do some grinding like Tim Potter had to do. It does rub a bit on the bulkhead where the screw is, but all it has done is messed up the label a bit. I run mine with the positive terminal close to the spur. I took a hard hit to the side that the lipo was on and the battery didn't even move with it being taped down.
I'll take a pic when I get home from work this evening for you.
XACDesigns is offline
Old 01-21-2008, 01:38 PM
  #1104
XACDesigns's Avatar
so has anyone tried using a rear diff in the front??? I really need to figure out something before the Snowbirds next Monday and don't want to run the spool on carpet if I don't have to.
Old 01-21-2008, 02:18 PM
  #1105
Centerline Racing's Avatar
Trader Rating: 47 (100%+)
I've been running the front diff from serpent for about 2 months now in two of my s400s. Like it a lot, but I want to try the gear diff...
Centerline Racing is offline
Old 01-21-2008, 02:30 PM
  #1106
XACDesigns's Avatar
Here is the 3600 lipo installed before and after lead. Sorry for the quality of the 2nd pic. The clearance is close, but neither the case or the positive lead rub on the pulley!
Old 01-21-2008, 02:31 PM
  #1107
XACDesigns's Avatar
Cool! I know they make a front diff kit, but I just cannot find them anywhere!
Old 01-21-2008, 02:57 PM
  #1108
Sorry, didn't get that from your post. You've probably exhausted all avenues. But, check if your LHS has MMR as a supplier. That's how I got mine.
Old 01-21-2008, 05:16 PM
  #1109
DaveW's Avatar
Sorry for the n00b question, but i know nothing of this car... yet. Would a rear ball diff fit the front? Are they the same? Thanx again.
DaveW is offline
Old 01-21-2008, 07:52 PM
  #1110
spurgear's Avatar
This is the grinding i did.
This is below the T-bar. I grinded half so it can still lay flat.
Closeup shot close to the pulley
Maybe too close?
Overall shot with the battery in place unsecured
spurgear is offline
