Serpent to 1/10th EP Touring Kit S400 >
Old 09-10-2007, 12:41 PM
  #421
Trader Rating: 19 (100%+)
Originally Posted by yyhayyim
What's the spring rate on the S400 orange and yellow springs?
I believe right around like yellow is 16 and orange is around 19. That might not be the exact but somewhere close.
Bryan
Originally Posted by Marcos.J
hey lilb your serpent looked great today!! should be real good next week at Kraceway
Thanks I am extremely happy with the car....
teammidget lilB is offline
Old 09-10-2007, 12:48 PM
  #422
Yesterday I ran at a different track than I did on Saturday. The car was awesome I made some changes do to the track being extremely hot. The changes from the stock set up was:
Front droop=2.5mm over ride height
Rear droop=2.9mm over ride height
1mm shim under the inner ball stud front and rear.
40wt oil
The only thing else I did was when the track was cool was lean the front shocks in one hole to get a little bit more steering. But when the track was hot I stood them back up to the stock setting cause the car would loosin up..
Bryan
Old 09-10-2007, 06:21 PM
  #423
yyhayyim's Avatar
Trader Rating: 26 (100%+)
try this set up lilb ! ( i ran 3.5 brushless but it should be good in stock and 19t)
front
4 degrees caster
.5 degree toe out
4.5 mm ride height
6.0 mm droop (droop gauge)
1.5 degree camber
1.5mm shims under both front and rear pivot blocks
3.0mm shim under inner camber link (long camber link)
30wt shock oil
shock lenght 66.5mm
2 hole piston
20% rebound
Tamiya Yellow spring
shock mount 3rd hole from the top
outter bottom shock mount
red sway bar
rear
3.0 degrees toe in
6.0 mm droop ( droop gauge)
1.5 degree camber
1.5 mm shim under both front and rear pivot blocks
no shim under camber link on rear hub(mount in middle hole)
1.5 mm shim under inner cambelink
30wt shock oil
shock lenght 66.5mm
2 hole piston
20% rebound
middle bottom shock mount
yellow sway bar
Where did you get that set up from? Dont tell me you already got one?
yyhayyim is offline
Old 09-10-2007, 06:55 PM
  #424
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
lol
thats the set up thats on the car now its sweet!!!
Marcos.J is offline
Old 09-10-2007, 07:15 PM
  #425
Didn't you know Marcos owns one or 2 of every car even those that aren't out yet.
Sydewynder is offline
Old 09-10-2007, 07:48 PM
  #426
Super Moderator
Marcos.J's Avatar
he is a little slow he is from south florida
Marcos.J is offline
Old 09-11-2007, 06:29 AM
  #427
yyhayyim's Avatar
all the off road nitro fumes are getting to me...
well, how is the car? Mine was working really well on its time out...much better than my Mi3...it took me a few days to ge the Mi3 working nicely, and even so, the S400 already is faster and easier to drive...I just hope its durable...
yyhayyim is offline
Old 09-11-2007, 06:38 AM
  #428
yyhayyim's Avatar
Marcos J: What rate are the Tamiya yellow springs you're using? I trying to order some...are these it?: http://www2.towerhobbies.com/cgi-bin...?&I=LXFAD6&P=7
yyhayyim is offline
Old 09-11-2007, 08:00 AM
  #429
Super Moderator
Marcos.J's Avatar
this is the spirng kit that i bought
http://www2.towerhobbies.com/cgi-bin...&I=LXWB01&P=SM
tamiya yellow long springs are like 13 lbs
Marcos.J is offline
  #430
They are like 13.9 or 14 pound springs.
Bryan
Old 09-11-2007, 08:01 AM
  #431
Super Moderator
Marcos.J's Avatar
Bryan
13.33 actually
Marcos.J is offline
Old 09-11-2007, 09:30 AM
  #432
Shop Owner
nnick's Avatar
Hello,
What is the internal ratio of the car?
Thank you
Nick
nnick is offline
Old 09-11-2007, 10:33 AM
  #433
Originally Posted by nnick
Hello,
Thank you
Nick
2.1875
Nick Simpson is offline
Old 09-11-2007, 03:35 PM
  #434
yyhayyim's Avatar
Bryan
Serpents Yellow is rated 1.4, which Xray say is 14lbs on their yellow springs...Serpent Orange are 1.7, which Xray says is about 17lbs on theirs?...Xray and serpent have very similar ways of doing things so the spring rats might be the same...I just need to know for sure...any Serpent 710/720 drivers know what spring rates the Serpent yellow and orange?
yyhayyim is offline
Old 09-11-2007, 06:22 PM
  #435
Trader Rating: 14 (94%+)
LOOK IN THE BACK OF THE MANUAL IT WILL TELL YOU ALL THE COLOR RATES
WHITE 13
YELLOW 16
ORANGE 19.5
RED 23.5
PINK 28
BLUE 33
PURPLE 39
GREEN 45.5
GREY 51.5
BLACK 57
j manikis is offline
