Alex Racing Barracuda R2 & R3
#9196
Originally posted by Ko Racer
question....... you guys running the R3 are you running the 59.5 shock length on all fours like the manual says?
58 was using inner hole at sus arm. Trying to get more steering.
#9197
SPRING RATES
somebody ask about spring rates?
here ya go...
SPRING RATES:
Spring Rating [lb/in]
1.5x5.00 23.81
1.5x5.25 21.58
1.5x5.50 21.05
1.5x5.75 19.32
1.5x6.00 18.52
1.5x6.25 17.09
1.5x6.50 16.39
1.5x6.75 15.50
1.5x7.00 14.76
1.4x5.50 15.69
1.4x5.75 14.65
1.4x6.00 14.39
1.4x6.25 12.42
1.4x6.50 11.87
1.4x6.75 11.66
1.4x7.00 11.36
Rayspeed
Gray 19.9
Red 18.26
White 17.17
Yellow 14.87
Blue 14.29
Green 13.2
here ya go...
SPRING RATES:
1.5x5.00 23.81
1.5x5.25 21.58
1.5x5.50 21.05
1.5x5.75 19.32
1.5x6.00 18.52
1.5x6.25 17.09
1.5x6.50 16.39
1.5x6.75 15.50
1.5x7.00 14.76
1.4x5.50 15.69
1.4x5.75 14.65
1.4x6.00 14.39
1.4x6.25 12.42
1.4x6.50 11.87
1.4x6.75 11.66
1.4x7.00 11.36
Rayspeed
Gray 19.9
Red 18.26
White 17.17
Yellow 14.87
Blue 14.29
Green 13.2
#9200
Hi Guys,
Thanks for the compliments, I'm glad you guys like the site.
Ova,
no problem Glad to see you're doing well with your cuda.
Steve Wang
Ova,
Steve Wang
#9202
Re: SPRING RATES
here ya go...
SPRING RATES:
1.5x5.00 23.81
1.5x5.25 21.58
1.5x5.50 21.05
1.5x5.75 19.32
1.5x6.00 18.52
1.5x6.25 17.09
1.5x6.50 16.39
1.5x6.75 15.50
1.5x7.00 14.76
1.4x5.50 15.69
1.4x5.75 14.65
1.4x6.00 14.39
1.4x6.25 12.42
1.4x6.50 11.87
1.4x6.75 11.66
1.4x7.00 11.36
Rayspeed
Gray 19.9
Red 18.26
White 17.17
Yellow 14.87
Blue 14.29
Green 13.2
here ya go...
SPRING RATES:
1.5x5.00 23.81
1.5x5.25 21.58
1.5x5.50 21.05
1.5x5.75 19.32
1.5x6.00 18.52
1.5x6.25 17.09
1.5x6.50 16.39
1.5x6.75 15.50
1.5x7.00 14.76
1.4x5.50 15.69
1.4x5.75 14.65
1.4x6.00 14.39
1.4x6.25 12.42
1.4x6.50 11.87
1.4x6.75 11.66
1.4x7.00 11.36
Rayspeed
Gray 19.9
Red 18.26
White 17.17
Yellow 14.87
Blue 14.29
Green 13.2
#9203
Hey guys, like the pics of the R3 keep em coming.
Alex USA site looking fab too, well done Steve.
Anyway, Johnny 55, I have run my cuda on both newer ( 1 year old) and older (10 year old) tarmac tracks with Rayspeed springs, Had blue up front and yellow on the rear, although did change to yellow all round when it got damp. Track surface was cold at 5 degrees which is normal for the UK (most of the year ) Car was very easy to drive and was developing much more grip than anybody else outhere, Would have qualified 3 rd in mod with a 27T quad mag!!!
Will be getting the alex 1.4 springs as soon as I can and have someone ready to colour code them for me
Can anyone comment on the wear rate of the titanium axles compared to the kit versions....Thanks
#9204
I like the Alex springs on the cuda kit shocks with yokomo bladder caps, they're ice and smooth and with the Alex springs there are no ride height problems.
I'm sticking with the Rayspeed reds and whites now jus because they seem to give a great balance to the car. I would have thought they'd be too hard for wooden floors but they're working great, balance seems more important than anything.
Steve the new site looks very slick
Could do with the spring chart rc-zombies posted so we can direct people there whenever they ask
I haven't seen any excessive wear with the titanium axles, rears look like new, fronts I haven't had apart to check recently bu they feel fine. I'm only running stock though and low grip doesn't put too much stress on them. I'm not hitting much either, honest
Just finished my new mazda 6 shell for Sunday's Scottish GP, it's erm.... different will see if I can get a photo on sunday.
#9205
I experienced excessive wear on one of my rear titanium axles during the drive train break in process. I was using the Xenon aluminum rear hubs and the bearings were not a good fit. The axles wore a noticeable groove and caused a lot of slop in the rear axle/bearing/hub assembly. I put in a new axle with the stock plastic carriers and everything is as it should be. Not sure what the tolerances should be on the Xenon hubs but they seemed a little sloppy.
#9206
#9207
Sounds like a hub or bearing problem, which is strange.
The bearings fit very nicely in my Xenon hubs, easy to slip in if you make sure it's square. May have been a duff bearing or the hub was machined badly. Pics would be handy.
#9208
R/C Tech Elite Member
Originally posted by SpeedTech
Hi Guys,
The new Alex Racing USA website is up and running. I'm still trying to complete a few sections, but you guys will get the idea of what the new look is like.
I apologize for not updating enough, but I'll try to keep up better with this new one. Please update your book marks:
www.alexracingusa.com
Steve Wang
Hi Guys,
Steve Wang
