Alex Racing Barracuda R2 & R3
#8686
Servo horn Q.
hey just wanted to know if you guys are using any other servo horns other than the ones that come with the R2. Wanted to see if a horn that comes with the TC3 would be ok on my Airtronics servo. It's just a little bit shorter than the one that comes with the kit.
#8687
I used a standard Futaba horn when I couldnt locate the one I had with my kit, the holes didnt match up, one either side of the Alex horn...just typical, anyway, I didnt notice any difference with the sterring once I had reset the turning circles/ throw and rate. The are a lot cheaper too, if a little bit more flimsy looking. Havent had any breakages yet though. (Fingers crossed )
#8688
Re: Servo horn Q.
#8689
An aluminium servo horn would be nice, if you need the extra weight, and well yes the cuda needs extra weight but no servo saver and a high priced servo....
I think I'd rather leave the servo saver in there thanks The Cuda's yokomo borrowed one is very tough anyway, doubt it will ever tweak on impact.
As long as your servo horn isn't widly different then it should be fine, especially if you have a nice computerised radio so you can change steering travel to suite.
#8693
Just started putting my R2 together... what's the word on shimming the diff/one way? Should I run the two thin shims on each for now or is there a better method? The bits on the end of the center shaft were a bitch to install too... had to wack 'em in!
#8694
Ran the Cuda at the Novak race in Milwaukee...i ended up taking 1st in the B main stock rubber and qualified half a second from making the A....i didnt have a good setup but im sure i coulda done better with more time...car ran greast just didnt have to to test setups...oh well...theres always next year
#8696
R/C Tech Elite Member
#8697
j/k
#8698
#8700
Is it possible for anyone to post the supplement sheet speedtech puts in the R2 kits? Mine was bought third party and i'm curious to know what's in that sheet.
