Alex Racing Barracuda R2 & R3
#3631
i thought dave was gonna post the shock pics up?
#3634
Dave is right, my Cuda is fully loaded and looks so good. Then again the TC3 is the IRS spec with the eye candy too. Ain't in the same league as the Cuda....on all counts!
Dont know if it needs anything else, but whats in the pipeline...who knows.
Dave, any ideas??????
#3635
-Dave
#3636
Noted, and will remember to ask too
How do you load up a fully loaded car?????
Ah well fotune favours the brave.
#3637
more goodies
there's more that comes out for this car than three others put together
wether thats a bad thing or not depends on your wallet and your self control
#3640
which wrench will i use the most on the cuda?
#3641
If you want to save money you can get a cheap allen key to do the CVD's/pinions, 1.5mm is what you need.
I would be suprised if you don't have a philips screw driver that is suitable already somewhere in the house, it's a very common tool for all sorts of houshold items.
You'll also need something for the wheel nuts and shock mount nuts, can't remember the two sizes, the HPI cross wrench does both and should be cheap from a model shop, it also does turnbuckles and another size of nut.
#3642
i plan of gettin the rcscrewz stainless steel kit... is stainless a lot better than stock?
#3643
1. although you can get philps stainless most r/c stainless are hex head
2. depending on individual they may look better (like ti screws)
3. if your in santa barbara then they won't rust (being close to ocean)
other than this I wouldn't say they do anything more or less than the stock screws.
#3644
There is nothing wrong with the kit screws other than they use philips heads, which can strip if you don't have a good fitting screw driver and don't put enough pushing force into the screw. I find I strip them a little too easily, mostly because I have slightly weak hands made worse by a broken arm a few years back
#3645
so they arent stronger?
