Alex Racing Barracuda R2 & R3 >
Like Tree5Likes
Old 07-20-2003, 06:11 AM
  #1771
Regional Moderator
Originally posted by JDM_DOHC_SiR
I usually mount the shocks on the 2nd or 3rd hold and they are breaking.....
here is my list of strongest to weakest front towers..
1)R1 2.6mm
2)PAL R1 2.6mm
3)K-modles 2.3x2(but still breaks at the base of the 2 pieces
4)R2 2.8mm
5)FLAP 3mm but to thin towards the outside mounting locations
-Dave
wow i guess im lucky i havent broke a shock tower in a looooong time knock on wood lol but maybe they will come up with something if others are having the same problems
Ko Racer is offline
Old 07-20-2003, 06:13 AM
  #1772
Regional Moderator
Ahhh yes Kitomas ....air scoop design that he borrowed from Masami`s Home Page heheheh ....it looks like it would work quite well if you motors get rather hot....but I have yet to have a cooling problem with my motors on any of my Cuda`s
-Dave
you are good bro and yeah i havent had a need for a air scoop either.
Ko Racer is offline
Old 07-20-2003, 06:15 AM
  #1773
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Yep.... Include the R1 shock tower with the R2 kit hehehehe j/k
BTw you`ll have the Pic`s of the CE-4 here in a bit Joseph
-Dave
JDM_DOHC_SiR is offline
Old 07-20-2003, 06:18 AM
  #1774
Regional Moderator
-Dave
thanks bro hey you have seen this rear brace any where?
Ko Racer is offline
Old 07-20-2003, 07:36 AM
  #1775
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
speaking of air scoop for the motor here is a picture of one
Hmm, I hadn't even thought about getting a heatsink, but I might have to do that. I'll see what the TC3 ones run.
Randy Caster is offline
Old 07-20-2003, 07:38 AM
  #1776
1)R1 2.6mm
2)PAL R1 2.6mm
4)R2 2.8mm
-Dave
I think I'll be switching both cars over to the R1 tower for sure. Does the rear tower need to be changed out?
Old 07-20-2003, 07:40 AM
  #1777
-Dave
With the way I gear my cars man, I need the cooling. I was running a 6.4 ratio at SoCal last tuesday until I geared down for a little more torque, still, I ran a 6.8. My stuff gets HOT.
Old 07-20-2003, 07:41 AM
  #1778
I have seen a couple pics of that brace, do you know where to get it, I really want one, seems like it would stiffen the car up a lot.
Old 07-20-2003, 03:15 PM
  #1779
nope the rear tower s just fine ......
-Dave
Old 07-20-2003, 03:19 PM
  #1780
Yep I have seen it but a better version of it...my buddy was going to make one similar to it a few moths back...but he ended up droping what he was doing and bought a Kai chassis ..as for that brace you can make it out of a old R1 chassis piece... or you can go the easy route and drill a hole in the lower chassis like the web R2 and use tie rods to tighten up the rear
-Dave
Old 07-20-2003, 06:47 PM
  #1781
Now you intrigue me with this Kai chassis. Any pics Dave?
Old 07-20-2003, 06:52 PM
  #1782
forty6's Avatar
http://www2u.biglobe.ne.jp/~kmodels/r2kai.htm
forty6 is offline
Old 07-20-2003, 07:06 PM
  #1783
Cool, thank you. I have seen pics of it in the past. Looks like it would be lighter than stock, but have more flex...
Old 07-20-2003, 07:18 PM
  #1784
Regional Moderator
-Dave
yo dave send me the pics bro when you can
Ko Racer is offline
Old 07-20-2003, 07:55 PM
  #1785
Is the CE4 the car with the motor front mounted?
