Yokomo MR-4TC SD
Originally Posted by pops
easy-e are you running a SSG? I see the SSG shock towers but can't tell what chassis you are running?
Parma Purple and Plaids should help as mentioned.
ssg shock towers, black special lower chassis, custom top 3mm top plate.
So what about the slop in my steetring ? Any suggestions , i cant tell if i torque steer or my car is wondering , but it suck to fight a car down the straight.
Setup seems cool with everyone i suppose .. just change my tires alittle. Im going to try some things and let you all know how it goes. !
yea i agree torque steer is a myth
ill see about reshimming my a-arms. any ideas for steering slop ?
Originally Posted by seaball
the two are a function of each other. torque steer is not nearly as apparrent if your steering is nice and shimmed. the torque steer ends up taking the steering slop and moving it all in one direction so the car really drifts hard under accelleration. i have not found torque steer to be a problem in a well built car. at least not in stock and 19T.
you're a good man.
Anybody knows where I can get titanium hinge pins? I want to build my LCG as light as possible.
First, use yokomo anti-roll bar ballcups(open type) with standard yokomo ball studs.(less expensive)
Second, use HPI ball studs with standard yokomo ballcups.(more expensive)
Perfect fit, no slop at all.(not good, I will give a full refund )
be careful if you run on a track with 2x4 walls. even 3mm titanium pins bend pretty easily, and the yok car uses 2.5mm. i personally, am going to use drill blanks (tool steel). they either break, or remain straight.
are the battery straps from the BD and the SD the same ?
anyone know where i can get a .pdf file of a cgm manual in english?
